How-To's - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-13-2002, 01:20 AM
Halloweenking's Avatar
Fantastically cannibalistic!
Post How-To's
I would just like to let everyone in need of autobody or interior how-to's or step by steps know that I will be posting some in my photo album for future refrence. If you have an idea for a how to or step by step or are in need of either and it is not in my album please let me know and I will create one and add it. It will take a few days to add all that I have typed up so be patient. If you have any specific interior question please direct them to Vintage because he is a trained professional that does very good work. Any question relating to autobody or metal customizing I am fully prepared to answer.
HK
Old 10-13-2002, 01:52 AM
roys63's Avatar
Post
I was thinking Again!,to install the headliner in my 63 Impala, any tricks to do this, the front has to be glued up , no tack strip, I have done this in a lot of boats but this hangs on the wire stringers, The trim shop here wants about $300 to do this just labor and it's 200 miles away, Thanx in advance. Scott
Old 10-13-2002, 06:19 AM
Post
any of your step by step or how to's would be great. They are easy to understand and cut right to the chase.
thanks alot for sharing your knowledge with the rest of us that are still learning this stuff or that just want to try something new
Old 10-13-2002, 07:23 AM
BOBCRMAN@aol.com's Avatar
Post
ROYS 63 to install a headliner you at home you will need glass out, buy a good quality headliner, (beleive it or not J>C>Whitney offers a very good line) you will need a good hot hair dryer,3M high tack trim spray glue,a bucket of water with just a squirt of dish soap in it.
install all the bows in the cloth channels of the headliner, do'nt mix em up, center each one from side to side, then take water and a sponge and wet the backside of the vinyl, working toward the outside. leave the outer 6 inches dry. then hang this assembly in the car using the original bow holes. start at the center and work to the sides untill all is smooth, then glue the front and back of the inside roof, starting at the rear stick the headliner to the body, center to sides, keeping it tight. then do the front. clue the body sides and stretch the material from the middle to each side and glue, when you get this all done if there are any small wrinkles in the liner use the hair dryer and care fully head around the wrinkle it will go away, because you are shrinking the vinyl backing which was wet.
Old 10-13-2002, 07:26 AM
Post
ran out of room!! after all this work you will probably drive to the trim shop and gladly pay the price!! I was a trimmer as a kid and through college, thanks bob
Old 10-13-2002, 08:09 AM
roys63's Avatar
Post
Bob, thanks for the info on this, i will take it to the trimshop that said that they can install it with the glass in. Thanks Scott
