How to upholster windshield posts ? ? ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2010, 08:21 PM
Old Fool's Avatar
I have a 1965 Musstang and wish to upholster the windshield posts to have a more modern look to the.
My thoughts which mot likely are not the easy way to go about this task are:
Cover the windshield posts with urethane foam, shape as desired, fiberglass, remove, upholster and then reinstall.
What are other ways to do this task?
Old 08-27-2010, 09:43 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
I don't understand why you want to make a '65 'stang have a modern look . I like it all original .
Old 08-27-2010, 10:08 PM
DanTwoLakes's Avatar
Wiki Edits: 22
Yes, why would you even think about doing that, it really doesn't make sense. You also have about four steps to your process when two would work fine. What would the urethane foam step and the fiberglass step accomplish other than making the posts as fat as a Churchill cigar? It wouldlook stupid in that car. Can you explain better why you want to do this?
Old 08-28-2010, 07:44 AM
Old Fool's Avatar
So you are saying just glue the upholstery to the metal post? How would I mount tweeters and hide the wires?
Oh, you ask why? Because it is how I want it, part of what hotrodding is all about I thought, making it your way.
Old 08-28-2010, 09:55 AM
Wiki Edits: 22
You are absolutely right, you should do it the way you want. You didn't say why you wanted to cover the posts. Where are the tweeters going to be mounted? Are there moldings that covers the posts?
Old 08-28-2010, 11:38 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
The way I would approach this is to go on the inner body in the kick panel area and cut a hole with a hole saw and run a electricians fish tape up thru the window post and pull in my wire bundle to overhead..then on the window moldings a fellow could use contact cement and wrap the existing molding...now it may be easier to run the wire bundle to the rear of the car and up thru the sail panel and then to wherever and what ever like to a overhead console..Longer wire run but maybe more practical..Gotta make life easy for the stitchers and trimmers..
Sam
Old 08-28-2010, 05:05 PM
Old Fool's Avatar
Sorry I didnt say why I want to do it this way. It is because the complete dash is from a 2001 Mustang GT and I want the posts to match the late model look as close as possible. I also want a pair of tweeters mounted in the upper corners of the a pillars and would like to have them moulded in, not surface mounted.
Old 08-29-2010, 07:34 AM
Wiki Edits: 22
Then what you need to do is make removable moldings to cover the posts and upholster them. Fiberglass is probably your best bet. Then you have to create a mounting hole for the tweeters in the posts, run your wires, install the speakers, and cover them with the moldings you make.
Custom windshield??? zbhover Hotrodding Basics 8 03-15-2009 11:21 PM
New Posts goes straight to Search Forums 66Caprice Hotrodders Site Suggestions and Help 2 03-09-2005 05:57 PM
should Lounge posts count towards post total? Jon Hotrodders' Lounge 107 10-20-2004 08:42 PM
new board feature: unanswered posts Jon Hotrodders' Lounge 8 07-27-2004 08:57 AM
