How To: Using TBI PCM for 4L60E Control. - Hot Rod Forum : Hotrodders Bulletin Board
Closed Thread
Old 10-26-2010, 11:33 PM
FastOrange's Avatar
Well, I finished swapping a Carb 350 into my truck, i am using the stock TBI PCM to control the 4L60E, this could be adapted to pretty much anyone wanting to use a 4L60E, not sure about a 4L80E.
DO NOT ATTEMPT THIS IF YOU HAVE EMISSIONS!
Transmission Control Via TBI PCM:
First off, Here is what the PCM needs to operate the 4L60E
-Vecile Speed Sensor
-Coolant Temp Sensor
-Throttle Positioning Sensor
-A RPM Signal
Now i did the exact same thing 04SilveradoMykk did in his thread with his Vortec PCM, But my truck was stuck in limp home mode.
Mykk's Thread on GMFS -> http://www.gmfullsize.com/forum/showthread.php?t=145089
I am running a MSD HEI Distributor, and it is what i would recommend for a similar swap, I WOULD NOT keep the TBI Distributor, you have no clue as to what the PCM is gonna do without seeing fuel.
Now with a TBI engine, there is no crank sensor telling the PCM if its running.
It took me about a week to figure out what to do, but when i did its easy as 123.
1.Find the plug that used to plug into the Distributor and lead to the PCM.
2.Find the Purple/White wire
3. Take Wire and run it into the TACH position on your HEI Distributor.
4. Done!
Picture of wire with a quick disconnect.
Here is a Picture of Holley TPS kit on my Holley 670CFM Street Avenger
Picture of whole setup on my orginial 350 with a Demon, engine and setup have changed abit since then
my Speedo, Coolant temp and all other gauges work like factory.
Quick reply to this message
Old 10-29-2010, 08:00 PM
LATECH's Avatar
Thats pretty neat that you figured that out.It will prove real handy for hotrodders to have that info. You can set up your ride with a minimal amount of sensors and wiring use GM parts (Budget minded) and run locally available parts when needed for repair. ( important for the sunday ride) way to go
Old 10-30-2010, 09:43 PM
FastOrange's Avatar
Well it was pretty easy for me (Engine is in a 1994 C1500) it took awhile to get all the bugs worked out but it sure saves from having to buy a standalone computer!
Parts are cheap and plentiful! (the sensors can be found on ANY TBI car/Truck)
Plus the Holly TPS Kit is $150 and it includes its own TPS, i ended up breaking it (Off shore junk) but just replaced it with a GM TPS (Cheap and plentiful)
Thanks for the compliment! hoping it could save someone some $$
Old 10-31-2010, 12:00 AM
tach
i have a 1988 gmc s15 two wheel drive pickup with 4.3 litre engine how can i tell if i have a 4L60E or th700r4 trans?????and how can i wire a tach into my truck
Old 10-31-2010, 02:00 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
I made this thread a sticky, good stuff.
The Following User Says Thank You to M&M CUSTOM For This Useful Post:
jasnstina (11-11-2016)
Closed Thread
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Need some help with 1986 GM 305, TBI or Carbed??? dieselcruiserhead Engine 8 12-19-2010 07:32 AM
tbi to qjet - how to connect cruise control? darefugee Engine 12 11-18-2010 08:27 PM
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
700R4- full manual control powderbill Transmission - Rearend 4 02-11-2005 09:03 PM
