How to verify crank and cam markings? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-01-2010, 02:18 PM
truckboy61's Avatar
I am almost ready to install new cam and want to make sure I line cam and crank correctly. The cam sprocket has typical divot mark but crank has what appears like a triangle mark? I've never seen that before is that the correct mark to place head to head?
Old 10-01-2010, 02:30 PM
techinspector1's Avatar
Wiki Edits: 326
Look closely at the crank sprocket. It may have a "0", a square and a triangle.
copied from NorthernAutoParts.com
"Standard Timing Location:
This is the same as original O.E.M. setting. Use keyway and crankshaft gear tooth marked O.
4 Degree Advance:
Use keyway and crankshaft tooth marked with a Triangle. Note: The Triangle or advanced position should not be used without degreeing the camshaft. Many camshafts have the proper advance built in. Advancing the cam will reduce intake valve to piston clearance and increase exhaust piston to valve clearance.
4 Degree Retard:
Use keyway and crankshaft gear tooth marked with a Square. Note: The Square or retarded position should not be used without degreeing the camshaft. Many cams have the proper advance built in. Retarding the cam will reduce exhaust valve to piston clearance and increase intake piston to valve clearance."
So, installing the cam "straight up" will be accomplished by using the 0 on the crank sprocket, then lining up the dot on the cam sprocket at 6:00 O'Clock and the 0 on the crank sprocket at 12:00 O'Clock.
Now, once you get it assembled like this, do not be confused about the ignition timing. With the cam sprocket at 6 and the crank sprocket at 12, #6 piston is firing. You have to rotate the crankshaft one full turn after you get the sprockets and chain installed to get #1 piston at firing position in order to set up the ignition timing and run the wires.
Old 10-01-2010, 03:45 PM
ericnova72's Avatar
More for Less Racer
If it has no other mark than the triangle, then that is the straight-up alignment mark for dot-to-dot with the cam gear.
Right cam for a 383? atomicrockerdude Engine 22 11-02-2009 12:13 AM
Crank Trigger and Cam Sensor tomtruty Engine 6 02-09-2009 05:59 PM
Cam Gear and Crank Gear Alignment DTL504 Engine 15 05-06-2004 05:29 AM
About to crank it up.....do i have the wrong cam ets1945 Engine 11 01-04-2004 01:29 AM
IGNITION and CAM TIMING sum87mustang Engine 3 07-11-2003 07:52 PM
