How to wake up a 1986 2.8 Pontiac Fiero ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-03-2008, 10:19 AM
the goal is to wake her up using the same 2.8 V6 engine
what can we do ?
any ideas ? suggestions ?
new defy !
Old 10-03-2008, 12:26 PM
racecar100's Avatar
Put a 3.1 In it will help alot. It's the same bolt pattern like the 2.8 and also lot better engine.
Old 10-03-2008, 12:27 PM
Yes i know
but the thing is to wake up that 2.8
Old 10-03-2008, 12:34 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Not much you can do without tearing into the shortblock. The usual trick is to bore and stroke, or use a 3.4 shortblock. If you're not keen on tearing into it, forced induction/nitrous is about your only really viable option. Even if you do all the "external" stuff you can like injectors, intake, TB, roller rockers, cold air, etc, you probably won't get much more than 5 hp.
A common combo is to use a 3.1 with a cam and some mild porting. That is usually good for a solid 170-180 hp. But, give your 2.8 about 7 psi of boost from a small turbo and you're looking at more like 250+
They're a nice little engine, I've owned several, but easy bolt-on performance isn't typical. go to www.60degreev6.com. They have some really great tech over there and the guys are good at squeezing some extra ponies from them.
Old 10-03-2008, 12:45 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
There is another popular swap, a L67. 240hp stock
Old 10-03-2008, 02:23 PM
SSedan64's Avatar
I swapped the TBI 2.8 in my son's 85 4WD Isuzu Troooper with a 3.4 from a 95 Firebird. Only thing I had to correct was the 3.4 block didn't have the mounting holes for a starter. It was a big improvement in power & MPG.
Old 10-03-2008, 02:36 PM
Banned
the supercharged 3800 also share the same bolt pattern.... and is a common swap in fierro's. I have a 2.8L in an S10- they suck. You can hop them up but for less money you can swap in a bigger better enigne and have more power and MPG.
Old 10-03-2008, 03:09 PM
LT1: http://dtcc.cz28.com/LT1build/index.htm
4.9: http://www.fieroaddiction.com/caddy49b.html
Old 10-03-2008, 04:04 PM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
Yeah you can stick about anything GM makes into a fiero. A 4.3 would bolt up nice. But then again so would a 454. And then you could do wheelies!!!
Old 10-03-2008, 05:31 PM
Jake_Dragon's Avatar
Last journal entry: New Carb
What 454 bolts up to the Fiero tranny
Old 10-03-2008, 06:19 PM
curtis73's Avatar
Wiki Edits: 16
There are adapters to put almost anything in a Fiero; SBC, BBC, Northstar, 3800, BOP. Its all been done before.
Old 10-03-2008, 06:36 PM
I know that, I have a SBC Fiero parked on my car port. Thats why I used a
The 2.8 is what it is, you get use to it or you buy something bigger.
I had an SE with a 2.8 and it was a blast to drive but didn't do so well in a straight line. My GT handles well and also kicks arse going in a straight line.
Old 10-03-2008, 06:43 PM
curtis73's Avatar
Wiki Edits: 16
Ah.. gotcha.
Quick google search turned up this. http://www.angelfire.com/fl5/fiero/fierolinks_009.html
Looks like some handy links for the fiero crowd.
Old 10-03-2008, 07:10 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Put Hemi in it!!!! I don't know if thats been done before.
Or do like Jake did
R
"SlowRide66"
"Illegitimis non carborundum"
Old 10-03-2008, 09:49 PM
curtis73's Avatar
Wiki Edits: 16
I often thought how cool it would be to put a Caddy 500 in it. Its a bit mismatched for the application, but I remember a guy who put a Caddy 500 in a beetle and it was fun.
Pontiac Fiero Owner swapping in a 350, maybe 383 sbc with a v8 archie kit Fiero Performance Engine 2 02-24-2009 05:30 AM
Pontiac Fiero Seats timkins Interior 13 09-28-2007 11:01 PM
smokey yunick's hot air pontiac fiero....for 4 Jaw Chuck 67GTO Hotrodders' Lounge 4 08-19-2007 07:43 PM
1986 pontiac trans am 1969supersport Introduce Yourself 4 01-18-2007 04:25 PM
1986 pontiac acaidian with a pontiac 400 mazmanian Engine 2 07-30-2005 02:35 PM
