how well with this cam work on blown 496 - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-24-2013, 02:04 AM
vinniekq2's Avatar
quite often like I have stated before,I use a tighter LDA and lower ICL on a smaller engine. The BB needs a wider LDA especially when building a 532 or that type of engine.(big bore moderate stroke,high revving).The blower engines are like bigger engines.
Scandi,you didnt mention what happens to the idle quality with a low ICL and narrow LDA
  #17 (permalink)
Old 06-24-2013, 11:59 AM
Scandinavian's Avatar
http://www.backfalt.fi/indexse
Last journal entry: Torque Converter
do you mean lika Thumpper cam design?
  #18 (permalink)
Old 06-24-2013, 12:32 PM
vinniekq2's Avatar
Scandinavian
use a thumper cam idle sound and compare that idle to a new corvette Z-06 idle.
put the stats side by side and explain why the big cam has a smooth idle and the small cam sounds like a race car,,,,
not wanting to get this thread off topic,just stating that specs are more than random numbers and sound does not tell the story.
more over lap Vs less
closing the intake early Vs late
How to make more top end Vs low end
BB requirements Vs sb
handicaps from limited head flow(thumpr cam territory)
etc
  #19 (permalink)
Old 06-25-2013, 08:25 AM
Scandinavian
etc
are we talking 12deg heads vs 23?
Blown 496 carbon fouling middle cylinders Blown496 Engine 1 05-17-2012 10:57 AM
I need another cam for my 496. dually502 Engine 0 10-14-2011 01:32 AM
blown 496 timing issue Blown496 Engine 4 10-10-2011 09:19 AM
Blown 496 cam recomendations Blown496 Engine 2 10-02-2011 07:36 AM
oval or rectangle port heads for blown 496 mean_1 Engine 9 07-22-2004 08:14 PM
