how well does it work - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2004, 12:58 PM
xtreamcurbin's Avatar
I have an '83 trans am with a 305 in it. i just put on a weiand x-celerator intake manifold, a 600 cfm holley that had work done to it, and a vacume advance distibutor. There is a cam in it, something better than stock from what i hear from the previous owner(3rd cousin owned it befor me, some one near him that he knows owned it befor him). Eveything else is stock except basic tune-up things(cap & rotor spark plugs/wires)
What im asking is how good of a combo is this, how much horsepower should it be
Old 08-02-2004, 12:34 PM
chevelle_502's Avatar
Get out the ducktape...
Last journal entry: Front brakes
Wiki Edits: 5
I wouldnt look for anything over 300 hp. Your only real power upgrades are the intake, carb, and cam so 300 is pretty close I feel.
Old 08-03-2004, 09:19 AM
oldschoolrods's Avatar
Last journal entry: Engine Compartment
I'm no expert but almost 1 horsepower per cubic inch with just a carb and a cam sounds a little ridiculous.
Old 08-03-2004, 10:10 AM
chev38's Avatar
Last journal entry: On the way to get worked on in KC
305?
The original 305 that came in that car was rated at about 165hp. The mods you speak of may get you to 195-200 hp. It takes a lot more than the mods you mentioned to get a 305 to 300hp.
That's why so many people use the 350. It's a much better base engine. The small valve heads and small bore of the 305 doesn't lend itself to small mods/big hp.
Old 08-03-2004, 11:17 AM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
well said, if you want some real performance, don't spend another day messing with that 305! Gears are your best bet for some more boot in the butt.
K
