How well should i expect a stock '37 Ford truck windshield to seal? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-12-2012, 02:16 PM
AZDoug's Avatar
This is the crank out windshield type.
Straight body, straight windshield frame, new gasket.
But i suspect it is gonna leak anyway, unless i add additional gasketing and never open it, as I see hints of daylight here and there on the sides. I may be able to crank the windshield tighter once it is warmer out and the gasket is more pliable, and I may be able to dork with the top hinges some to bring the windshield frame into its pocket a bit tighter
Any experiences?
I figured I will make sure the drain holes in the frame pocket are clean,and I have new rubber drain hoses installed to take care of leaks.
Thanks,
Doug
Old 01-12-2012, 02:37 PM
shine's Avatar
SPI Thug
Last journal entry: some progress
given time the seal will seat against the body. getting it adjusted is the best thing. couple of big guys to hold it tight while you tighten the hinges helps .
a coat of vasoline on the rubber helps it seal against the paint.
Old 01-12-2012, 04:53 PM
AZDoug's Avatar
Now that you mention it, it looks like I need to loosen up the hinges, and push the whole windshield into the pocket, then tighten/adjust/shim hinges as necessary to keep the windshield there.
It is sitting ~1/8" too low on one side for sure, and won't go into the pocket on the bottom.
Doug
90 ford truck steering box seal fast68 Suspension - Brakes - Steering 0 03-14-2010 03:24 AM
How much power can I expect from stock 305 Vortec heads produce? Lil Big Mec Engine 2 03-07-2007 09:50 PM
'32 Ford Truck Windshield Wiper Systems rcrfly General Rodding Tech 2 08-12-2006 09:50 AM
Windshield Seal Riverman Body - Exterior 1 06-28-2006 12:22 AM
Windshield seal installation, 37 Ford Coupe Ted's37 Body - Exterior 3 08-14-2003 09:51 PM
