how wide? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2006, 06:26 PM
defilade's Avatar
2012
how wide?
how wide of tires can I put on stock 10 bolt on 65 el camino without tubbing it out please give backspacing I want vintec cruzers with m/t sportsmans.
thanks
Old 05-31-2006, 05:06 PM
Of course it would depend if you want it to stay tucked inside of the wheel well---If I were you, being that you are in San Diego, I would take it to a custom shop and just have them measure it out real quick and do all the math for you so you know it is correct. They should do that for you for free if you are intrested enough in having them retail the wheels and tires for you;that way you KNOW it is correct and looks good.....just my suggestion
Suggestion on Muncie wide or close johken Transmission - Rearend 9 03-14-2006 03:12 PM
tires, how wide can I go? 29whippet Suspension - Brakes - Steering 2 04-13-2005 02:39 PM
What car has a 9 in ford less than 64 inches wide? BillyBob1950 Transmission - Rearend 2 02-12-2003 09:21 PM
How wide is a deuce? 5window Body - Exterior 2 07-25-2002 07:50 PM
wide whites pichoboxing Hotrodders' Lounge 4 07-07-2002 02:33 PM
