How wide would it be - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2007, 10:46 AM
iceman36's Avatar
Ok here is the first dumb question of the week, well maybe not dumb.
I plan on using QA1 ciol-over shocks with ½ “ eye loops on both ends and making brackets.
Making the brackets was no problem but I’m using a setup rod for now, so I don’t have the shocks. I plan on using sleeves with one welded in to maintain center and the other un-welded. I know it’s partly a matter of personal preference but.
The Question is how wide would the gap between the brackets be? Or how wide would a average Shock eye be with a rubber fitting not a solid bearing?
Questions about wide wheels and fender flares tcruise Body - Exterior 5 06-09-2006 05:50 PM
Suggestion on Muncie wide or close johken Transmission - Rearend 9 03-14-2006 02:12 PM
tires, how wide can I go? 29whippet Suspension - Brakes - Steering 2 04-13-2005 01:39 PM
How wide is a deuce? 5window Body - Exterior 2 07-25-2002 06:50 PM
wide whites pichoboxing Hotrodders' Lounge 4 07-07-2002 01:33 PM
