I run a 350/350 with a 3:08 rear end . It is just fine for the daily driver. It still smokes the fires. Yet i can cruise on the freeway.
So are you after the daily driver, or blow the doors off hot rod? Let us know what you do will ya? Slider in Wa. |
Slider
With the price of gas in England at 5 bucks a gallon I need a sensible ratio! More a weekender than a daily driver but its a 4 seater so don't want to scare the kids! Glad to hear it still smokes em! Limey Simon |
i went from a 4.56 to a 3.14 and lost a LOT of pickup, the funny thing is that mileage didn't improve a lot because aerodynamics play more of a part than rear drive ratio (at least in a Model A).
I think a nice 4.10 or 3.73 would be good if you want to blow the doors off a 5.slow mustang (which run those gears as well) |
Hello Limey. I'm running a little 327 Vette engine in a 36 Ford 5 window with a 700R4 and a 308 rear and it smokes along just fine where ever you want it. My rear tires are 28" diameter, but I agree with Slider. I think you will be very well served with the price of petrol and driving conditions on the Big Island.
Look at the photo of my Black 32 roadster beside the red 5W. I use a 3.50 in it. I have had a 3.00 in it. The 3.00 did well. My engine is a 350 crate engine. The 3.5 is some quicker but a the cost of 2 -3 mpg.
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
I'll can run your information through a computer program and produce a performance report and post the results if you like.
Post the following information and I'll have the data calculated. Tell me about the: Transmission: 3.08 Rear Gear Posi or Single: Stall Speed: Tire type and exact size: Weight of car with driver: Horsepower and torque numbers if known: Specs of engine: Redline of engine: I will run the numbers this afternoon and post the information. [ November 04, 2002: Message edited by: 2quik ]</p> |
Fine lookin' Deuce!
I am running a 350/350/12 bolt with a 3.31:1 gear in my fenderless Model A Tudor. It cranks about 2500 rpm at highway cruising speed (65 mph 'ish). Keep in mind that rear tire diameter makes a big big difference. There are quite a few variables to factor in when determining rear gear ratio. Check out website 4lo.com. They have a gear/tire size calculator that will tell you exactly what you will end up with. Good luck! |
Hey Limey Simon,
Your report is ready but you have the option to accept private messages turned off. See www.pchotrod.com to view your report. |
