how will a stock bottom end sbc handle 11.5 to 1 compression - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2011, 09:07 PM
MAKE EM STICK AND E.T'S QUICK
i have a 327 with a stock bottom end. ive installed cam, intake, aluminum heads. the issue is with 64 cc heads it was at 10 to 1. now the heads i went with are 58cc n im thinking my comression is around 11.5 to 1. this bottom end is just a temp. parts holder but how will stock rods, crank etc hold up? if not pushed to hard wil it hold?
Old 04-28-2011, 09:16 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Chevrolet built 327's with 11.00:1 static compression ratio many moons ago and controlled cylinder pressure with camshaft timing events. I don't think it's the cylinder pressure that will do you in as much as it is excessive rpm's.
Old 04-28-2011, 09:17 PM
Comp ratio
If the parts stated are in good condition higher compression won't hurt anything as long as you don't get into detonation. I don't think your CR is as high as you think...more like 10.8:1. Run 91 octane and you shouldn't have any trouble.
Ron
safe hp for stock bottom end sbc 350? dburkinshaw19 Engine 7 09-07-2010 08:40 PM
strongest stock bottom end? streetpirate Engine 17 09-19-2009 09:22 AM
What rpm is a stock Gen V 454 bottom end good for Hacksaw Engine 1 04-20-2009 12:31 PM
max rpm for a stock bottom end bbc? chevelle4542speed Engine 8 10-29-2006 06:59 PM
Most HP/Comp for SBC stock bottom end? bigmark Engine 8 04-04-2003 06:11 AM
