How To Wire My Horn - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2008, 01:43 PM
OLDFART952
How To Wire My Horn
Hi Guys, I Removed My Old Horn. I Have Two Hella Horns. I Need To Know How To Wire Them Up To A Switch Inside . Not To Steering Wheel. Any Ideas???? Thanks Guys
Old 05-26-2008, 05:34 AM
re
Well, in a column switch they usually switch ground, so that the button on the wheel requires just one wire, so you might want to do it that way in case you ever want to go with a 'normal' horn button
Old 05-26-2008, 07:42 AM
Street Rod Builder
The two horns should be wired to a relay. Ground the houns to the body of the car. The positive wire to the horns comes form the relay. The positive wire to the relay comes from your fuse panel. You can use the same positive wire to the relay to power the positive side of the relay. The negative side of the relay comes from your switch. It can be the horn button or the special switch you put in the car.
Don www.wolfcreekrodworks.com
Old 05-26-2008, 07:52 AM
JohnC - Kechi, KS
3 wire alternator hookup GCD1962 Electrical 10 04-21-2008 08:29 PM
One wire alternator question wisch79 Electrical 2 09-14-2007 07:19 AM
I need help about GM horns..wiring aftermarket horn GMCANYON Electrical 5 04-27-2007 08:11 PM
Battery problem? evltwin Electrical 11 04-10-2005 06:45 PM
horn problem wiseguy50 Electrical 3 04-02-2005 10:01 AM
