How to wire neutral safety switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2012, 05:56 PM
Hi Guys....have th350 with floor shifter c/w neutral safety switch. Need help on how to run wiring.
Thks.
Old 03-29-2012, 03:02 PM
ogre's Avatar
the 'Duracell Project'
cut the wire that goes from the ignition switch to the starter and feed it thru the neutral safety switch
this way you can't crank the motor unless it's in park or neutral
if your replacing a column shift nss then the wire is already fed to the nss on the column
just relocate the wires to the floor nss
Neutral safety switch/solenoid wire??? firstgear Electrical 7 02-21-2012 05:10 AM
Wiring Neutral Safety Switch / EZ-Wire Kit horvath Electrical 15 01-20-2008 12:35 PM
neutral safety switch jwash56 Electrical 2 05-24-2005 10:27 AM
Neutral safety switch jrmz28 Electrical 3 08-13-2004 07:06 PM
Ford C6 neutral safety switch wire colors cboy Transmission - Rearend 1 02-11-2004 05:19 PM
