How to wire Piezo horn from Mercedes SL500 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-19-2008, 01:40 AM
labreejr's Avatar
Ive got this horn I want to use for my alarm on my 84 Cutlass. Its a piezo style horn that makes that really high pitched annoying sound. It came from an 04 Mercedes SL500. It has three wires. I know 100% that it works, but when I connect to a battery I get no sound. I know one wire is power, one ground, whats the third for? I've tried every configuration. The horn also seems to have an internal battery, if that helps. Thanx in advance.
Old 12-19-2008, 05:15 AM
1947 Chevy Coupe
One might be permanent hot, one a ground and one a trigger you take to ground or hot to make it annoy the crook.
Old 12-20-2008, 08:38 AM
I think the internal "battery" is probably not a battery, but a relay. One power lead will be hot (fused, directly to 12 volts) and one will be switched 12 volts, using whatever kind of switch you want.
For the switched 12 volts you might be able to tap into the existing horn wiring under the hood and just use the stock horn button to activate the new horn.
Bruce
how to wire 12 volt oooga horn two-cylinder Electrical 10 07-02-2015 08:19 AM
I need help about GM horns..wiring aftermarket horn GMCANYON Electrical 5 04-27-2007 08:11 PM
One wire or three wire? Screwy Lewy Electrical 0 06-30-2003 04:33 PM
Wire Looms for 350 HEI with rams horn manifolds Jag Daddy Engine 8 03-17-2003 07:25 AM
57 Chevy generator to altenator swap Rodrunner Electrical 2 07-17-2002 09:59 PM
