How To Wire A Subwoofer ??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-31-2006, 11:01 AM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
is there a way to wire ONE single coil subwoofer to an amplifier that does not have a mono sub out jack?
I think I've seen a simple to build solution to combine the 2 channels into one, does anybody have a diagram?
please help.
thanks
Augusto.
Old 08-31-2006, 11:28 AM
bassdude404's Avatar
To bridge two channels into one sub, just run the positive lead to the positive post on channel one, and the negative lead to the negative post on channel two. Simple as that! Make sure that if your amp has a crossover built-in, that you set it for low pass. Otherwise your sub will be trying to reproduce the entire frequency range, and sound crappy. I used to have a subwoofer/tube setup hooked up just like this in a '87 Firebird, and it woorked great. Eventually ended up with a custom fit box with 2-10's for the same car.
Old 08-31-2006, 06:49 PM
Augusto's Avatar
in other words join both positives and both negatives ? can I still use the front chanels in stereo once the rear is bridged ?
thanks for your help.
Augusto.
Old 08-31-2006, 06:55 PM
gemini86's Avatar
Hey, mine's paid for, Punk.
no no, use ONLY the pos from channel one and ONLY the neg from channel two. this wouldn't work for say, a woofer or midrange speak, but for a sub it works fine.
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 10:45 AM
new welding wire oldred Body - Exterior 93 05-07-2009 05:40 PM
1986 Cutlass wiring Q's again :( ChrisMiddleron Electrical 12 07-16-2005 05:22 PM
One wire or three wire? Screwy Lewy Electrical 0 06-30-2003 05:33 PM
57 Chevy generator to altenator swap Rodrunner Electrical 2 07-17-2002 10:59 PM
