How to wire up a points triggered HEI module - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2007, 11:47 AM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
I have a 1975 ford bronco with a points distributor, I want to set it up so the points trigger a HEI module. I've read about people doing this before but I did a search and can't find anything. How does the wiring go? does the dwell / point gap matter anymore?
Old 11-16-2007, 05:03 PM
Wiki Edits: 2
I did some research and it turns out that with points it is better to use a ford TFI module, because the points put out a square wave signal.
http://www.gofastforless.com/ignition/tfi.htm
Old 11-16-2007, 05:22 PM
GSXMEN's Avatar
www.davessmallbodyheis.com is the way to go for that.
He can do a points style dist. conversion for you to either use an MSD/Crane box, or add a GM HEI module to run as a standalone (small body)HEI.
You can find him at www.buickthunder.com as IgnitionMan.
Hey Doc or any one who has tried to trigger an hei module with points? barnym17 Electrical 7 07-08-2007 03:22 PM
HEI Wire Positioning Unkie Engine 2 07-01-2007 12:15 PM
Procomp HEI and MSD module no go! Jmark Engine 5 12-03-2006 07:55 AM
Wire Looms for 350 HEI with rams horn manifolds Jag Daddy Engine 8 03-17-2003 07:25 AM
HEI plug wire placement RodneyUSAF Engine 2 03-04-2003 06:34 PM
