how wiring T-400 electric kickdown - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2013, 11:23 PM
hello
i have a th400 with an electric kickdown
the car is not set up for this kind off kickdown , before was the regular cable
any advices or tricks here ?
thanks a lot
Old 01-14-2013, 11:28 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by Vincentnova View Post
hello
thanks a lot
You can use a microswitch at the carb throttle linkage. I recall seeing a wiring diagram online, it's real simple. I see B&M sells a kit for this: http://www.summitracing.com/parts/bm...FQyDnQod8yQACg
The factory '69 Camaro harness connected at the wiper motor:
Old 01-23-2013, 12:15 PM
never seen or knew they made a mechanical kickdown for the TH400. I put a 400 in my 48 chevy pickup and just have a push button switch I can hit when I want it to kickdown. One of these days I will rig it up to the throttle but it works fine for now. Yogi's and other aftermarket places carry setups.
T-400 kickdown switch krunch007 Transmission - Rearend 4 09-12-2012 05:15 AM
T-400 vacuum & kickdown hookups tjet Transmission - Rearend 5 10-03-2011 03:11 PM
turbo 400 kickdown? hougie Transmission - Rearend 5 09-05-2007 12:59 AM
electric wiring a 64 chevelle wayne goff Electrical 1 06-02-2007 10:07 AM
Electric fan wiring? Boostedpimp Electrical 13 12-12-2006 11:44 PM
