You can install either by lapping the seam or by butt welding it. A lap weld may be a bit easier to weld for a beginner, but a little more inviting to corrosion at the seam. Use your patch panel and hold it up to the fender and trace where you will have to cut if possible. If doing a lap weld remember to leave enough material in from your traced line for overlapping. Also flange the edge of the cut so the pieces fit flush for welding. If butt welding cut out the same size of your patch and get a good tight gap. Error on the side of taking too little off, its always easier check fit and cut or grind more off, then to add material or place a wide weld. Don't cut until you are sure its right. Use clamps to clamp the patch in position if possible. If you lap weld you could just spot weld the seam area, but I think its much nicer, less inviting to problems if you weld the seam up. Weather lapping or butt welding, you don't want to weld the seam in one pass. You have to place short welds spaced apart from each other, leaving some time to cool in between to keep down warpage and avoid building up too much heat. Take your time and weld slow. Use a hammer and dolly to straighten the seam as you go if needed. The patch panel is not normally welded on both sides, just get good penetration with your weld. If lap welding use a weld through primer on the lap area and seam seal the inside of the lap with a good 2 part seam sealer. Coat the inside of the repair with epoxy primer or some sort of rust preventative coating. If butt welded, coat the inside with a rust preventative coating. Grind your weld, but don't grind it too thin. You can always tap the seam area in a little if you have to. Apply an epoxy primer over your repair, and finish the weld area with bodyfiller. filler can be applied over epoxy primer without sanding if its in its window. If not in its window or unsure, just scuff the epoxy up a bit with 180 grit before you apply your filler. Once your filler is sanded and straight, spray another coat of epoxy primer and after its sat awhile follow with a few coats of urethane 2k primer for block sanding and fill. If you think you might have voids or pinholes in your weld, you may want to put on a thin coat of fiberglass filler or all metal filler over the weld first before using a plastic filler. The first two are more resistant to moisture then plastic filler, but are harder to finish nicely.
If you need to see some pics look in my journal. I have been doing patch panels for the last few weeks.
Hey SCHOONER,If it were me,I would but weld it.The main thing with getting a good finished product is panel fitment.Take alot of time makeing the panel fit perfect,the maximum gap iI would allow for is 1/16 of an inch.After the panel fit to my likeing,I would tack weld it on the corners,and one in the center.Here comes the hard part........TAKE YOUR TIME!!!!DO NOT GET A HURRY!!!!Start tacking it one one end,wait for it to cool,then tack it on the other end,repeat this untill it is welded all the way across.It will look like crap,but dont worry,you can fix that.Make sure you get a good "burn" on every tack.After you have welded the whole seem,get a 24,or36 grit rollock disc,on a die grinder,and buff the weld down,as is you were trying to block sand bondo.Then apply your fillers and primes to tase!If you take your time,you shouldnt need much filler at all,and you will have a great repair!GOOD LUCK!!!!!
I don't think anybody else coverd this. You can take a piece of copper and hold it on the inside of the butt while you're welding to keep things cooler and it won't be as apt to warp as much. It makes it easier if you have somebody to hold it for you. It acts as a heat sink.
Danny |
If you've never mig welded sheetmetal then definately do some practice welding. Do some butt welded seams and also lap welded seams for your practice runs. Butt welding the patch in is what I prefer but as mentioned already alignment is key before you start welding. If your welding skills aren't very good then flange the joint and lap it. The copper backing is also a great way to control warpage and blowthrough but you'll definately need a helper. Practice up then fit the patch. Make sure your metal is good and clean where the weld will be-this aids in puddle flow and weld quality and also decreases the chance of blowthrough. Practice, practice... Bob
HEY KENSETH17 " THANK YOU "
First things First " THANK YOU " for such an in-depth instructions of which I just printed-out and when I ready I will refer to it. You really know you stuff. I know I won't go wrong with your pro-instructions. THANKS SO MUCH FOR YOUR HELP I really appreciated it GOD BLESS Schooner
http://www.jwharris.com/images/twentygauge.pdf
Here's the welding wire you want. It's meant for sheet metal and is very forgiving. It helps me be a better welder than I am. George |
HEY GATOR412 " UNBELIEVABLE PHOTO JOURNAL "
What a picture show that was on your projects. Man, I sure will use some of your Right Ways To Do Patches. GREAT JOB, AND THANK YOU FOR SHOWING HOW IT SHOULD BE DONE. GOD BLESS Schooner
Thanks Evilone For The Tips
Thanks THANKS AGAIN GOD BLESS Schooner
The Cooper Suloution
That sounds pretty cool I like the idea. However, where on earth would I get some pliable cooper for strapping the joint Any ideas where I can obtain such a piece THANKS DANNY GOD BLESS Schooner
Dynamite George ~ Great Info On Wire Usage
That reference you posted about mig wire and voltage was GREAT I just printed and I'm sure I will refer to it often ~ THANKS TO YOU GOD BLESS Schooner
Thank You For Your Imput Boddbob
I sure like the idea about the cooper piece of the backing and keeping the warpage down. But I'll go nice and easy on the spot welding. Just need some advise on where to pick-up that cooper I certainly will follow you advise just like all the other GREAT GUYS on this site who are helping me alone in my journey to completion of my '66 Mustang Convertible. GOD BLESS YOU Schooner
Not sure if it got mentioned, but do NOT use flux core wire. Flux core doesn't need shielding gas, but leaves slag and other junk.
The wire called "20 Gauge" by Harris (which someone else mentioned) is great stuff, but hard to find. If you can't find it, just use a regular .023 solid wire with shielding gas. Thanks, PeterM |
65comet, That wire is the best thing to come along for welding sheet metal since the invention of MIG welding! I have been using it for some time now and I can honestly say that NOTHING else even comes close for ease of welding on thin stock.
Schooner, This is Jw Harris stuff and any welding supply can get it for you, even some auto parts can get it. It is "Perfect Circle" brand by JwHarris in .030 size called 20 gauge (think twenty gauge shotgun not wire size, It even has a shotgun printed on the box )Also that power reference on the Jw Harris web site only applies to the 20 gauge wire and those settings will not work properly, if at all, with solid wire. That is what makes this stuff work so well, the fact that it will make a really good weld at such ridiculously low settings meaning less warpage, less chance of burn through and longer duty cycles on smaller welders. |
| "Basic of Basics" Welding - How do I repair body panels? | Centerline | Body - Exterior | 29 | 06-18-2009 06:54 AM |
| Parasol Metal body filler. | x711 | Body - Exterior | 16 | 02-14-2006 09:47 AM |
| Question on Mig Welding - HOW to | modas | Body - Exterior | 43 | 12-31-2005 09:48 PM |
| Welding Books | Magnus_Jager | General Rodding Tech | 6 | 11-29-2005 03:57 PM |
| Quarter Panel Patch | Ron M | Body - Exterior | 1 | 07-27-2004 01:12 AM |
