Howards Cams - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-30-2009, 06:24 PM
Banned
Originally Posted by techinspector1
Please explain in detail how this is possible. I am always interested in learning new methods.
I have a camshaft that has 240 degrees duration @0.050" with a lobe separation angle of 112 degrees and the lobes are symetrical from opening to closing flanks. What are the timing events, based on your statement here???
Oh, and just so you and the rest of the lads here know, there is no difference afforded by whether the opening and closing flanks of a lobe are symetrical or asymetrical. That part of the lobe profile has nothing to do with the opening and closing points ground into the lobe at the time of manufacture. An asymetrical lobe is used to jerk the valve open quickly and return it to its seat more gently to help prevent valve bounce on the seat. A lobe can be ground symetrically or asymetrically and still have the same opening and closing points.
symmetrical lobes can affect it because it changes where the CL's are at, do you mark the centers at the lobe peak or split the difference on the .004" numbers, the .001" numbers, the .050" numbers or the .200" numbers- all of them will give you a different centerline on the same lobe profile if it is assymetrical, and even cam manufacturers disagree on the best method.
  #17 (permalink)
Old 09-30-2009, 06:59 PM
Greg T's Avatar
www.krusinklassics.net
Am looking at the following:
Chev SB (Hydraulic)
Lift: .449/.449
Adv. Duration: 290/290
Duration @ .050": 224/224
Lobe Center: 108
Hot Street, 4bbl. & Headers Recommended
And:
Chev SB 262-400
Application: Max Torque
RPM Range: 1700-5700
Lift w/1.5 Rockers: .470/.470
Adv. Duration: 284/284
Duration @ .050": 220/220
Lobe Sep. Angle: 108
Recommended Valve Springs: 98214
But I wanted to kow how the intake closing coinsides with the Isky and the Crower.
  #18 (permalink)
Old 09-30-2009, 11:43 PM
Greg T's Avatar
Okay, one more question. Let's say the cam card shows an intake closing of 35* at .050. But the cam card also says 4* advanced. Does this 35* fugure mean the 4* advance is already accounted for, or if i install the cam normally without an offset key will it close at 31*? In other words, are the valve events posted on the card using straight up or 4* advanced timing?
  #19 (permalink)
Old 10-01-2009, 09:53 AM
Greg T's Avatar
I havent had the time to calculate anything since I spent most of the day yesterday in the ER. But, you're saying that the isky's timing card already reflects the 0* advance. So, in other words, just installing the can as directed by isky using the existing marks should be correct. Or. close to it depending on tolerances. I will check it, I'm just trying to clarify. Some cam cards make note that the cam is 4* advanced and I didn't know if the card timing frelected that or, if I installed using their timing marks the valve events would not coincide with the cards events. Does that make sense?
On a second note, the Crower I'm looking at says intake close at 37* but says nothing about advance. Should I advance that one 4* to get my targeted 35* . See, this is not a build. It's just a simple cam swap cuz I have a lifert collapsing in a stock rebuilt 350.
  #20 (permalink)
Old 10-01-2009, 11:33 PM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
Because I skipped over all the back and forth about cam degreeing, I am not sure if anyone has answered your question about Howards quality....I have used their stuff and it is on par with any of the Big Name valvetrain components out there. Usually the price is better but the quality is very very good. (if not excellant)
  #21 (permalink)
Old 10-02-2009, 03:15 PM
Greg T's Avatar
Well, that's really why I was looking at them to begin with. I know, roughly, what I want to throw in there for the time being and found it hard to swallow Isky's pricing. This cam will probably only be in service for a year or so as I am planning on making a drag truck of this S10. I just need it to be dependable until I get everything I need to do the project. Right now it is my daily driver and since I need to replace a lifter I thought I would just give it a little more snot and a tougher sounding exhaust note while I had it apart. I may just grab the Howards based purely on price alone. As long as I can get thru the break in process I should be fine. I don't even plan on changing springs for this motor.
  #22 (permalink)
Old 10-04-2009, 01:28 PM
Banned
for price alone builds its hard to beat Elgin. They have a pretty decent selection and good reputation too.
confused about camshafts (FSB) pstrbrc Engine 9 11-30-2008 09:02 PM
Howards Cams & Race components TorkMonster400 Engine 6 08-06-2008 05:17 PM
Comp Cams hydraulic roller vs. solid flat tappet comparison Mad Maggot Engine 23 02-13-2005 11:29 AM
Solid cams vs Hydraulic cams, preference or power? killerformula Engine 17 02-03-2005 10:42 AM
Know of any good cams? TurboS10 Engine 19 12-20-2004 02:46 PM
