How'd they make this work? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-10-2013, 06:10 PM
DoubleVision's Avatar
In the second world war, Russia released it's T-34 tank.
It was powered by a V12 diesel engine rated at 500 horsepower.
I was interested on these engines so I read up about them and when I did so I got somewhat of a surprise as not only have I never heard of this but I also didn't know it could be done.
What's different is the stroke depth.
On the left cylinder bank the stroke depth is 7.100
On the right cylinder bank the stroke depth is 7.300
When I first seen that it blew my mind as I was asking myself why would any engineer want to create a engine that had a unequal stroke depth?
My second question is with that much difference wouldn't it knock it way out of balance?
My last question is wouldn't the bank with the longer stroke create more torque and thus creating unequal loading on the bearings and accelerate wear?
Can anyone explain how they did this and made it work?
Old 12-10-2013, 06:49 PM
OLNOLAN's Avatar
Over balance
Seems that I've read about overbalance to gain reciprocating weight helping the swinging of the crank back around? Maybe some one here may know, it is interesting to read about. Torque?
The mobile view is crap
from a little bit of quick reading it sounds like only six of the rods were connected to the crankshaft then the other six on the opposite bank are connected to the beam of the rod connected to the crankshaft. Also reading that it wasn't famous for its reliability, the requirement was to last a minimum of one hundred hours and a lot of them didn't make it.
The V-2-34 is a version of the V-2 adjusted for the usage in the famous T-34 tank. It was a V-12 cylinder liquid cooled DOHC diesel engine with a max power of 500 HP at 1.800 RPM. The engine has the same design and output as the base V-2, it just received adjusted hull mounting, fuel and cooling connectors, as well as a refined clutch. The V-2-34 features an aluminum alloy body and is meant to be mounted lengthwise in the vehicle hull. Two cylinder banks with 6 cylinders each were placed in an angle of 60 degrees. The pistons are linked to the central crank shaft by wrist connecting rods, which means that only six rods are directly connected to the crank shaft. This special design also results in a slightly lower stroke in both sides of the engine. The right side has a stroke of 186.7 mm and 180mm in the cylinders on the left bank.
The V-2-34 is a DOHC engine, which means two overhead camshafts for each cylinder bank, one controlling the input and one the output valves. Each cylinder is has two input and two output ones.
The engine uses a dry sump lubrication system. Before engine start, the loader of the tank has to manually pump oil from the main reservoir into the engine. Once the engine is started, a mechanical lubrication pump takes over, which presses the majority of the oil onto the crank shaft and the connected rods. A smaller part if fed into the cylinder heads on the camshafts.
One large cooling radiators is mounted on each side of the engine, each responsible for one cylinder bank.
Two box type air cleaners were mounted to the rear of the engine. Each cleaner contained a cyclic filter, as well as oil soaking metal mesh for fine cleaning. Cleaning performance of this design was extremely bad, resulting in the low service life time of the engine.
Starting of the engine was done with an electric starter, mounted at the engine rear on top of the transmission. An auxiliary starter based on pressurized air was also available. It was using air from one tank mounted in the hull front. The tank was not equipped with a compressor, which meant that the tanks had to be filled using an external system.
Before starting the engine, the cooling liquid and the engine oil had to be brought to a certain temperature. This was mainly due to the fact that the oil used had a very high viscosity at low temperatures. As there was no pre-heater installed, the crews had two ways to heat up the liquids. First of all, the liquids could be taken out of the engine and warmed externally. A more combat like way was the use of a small stove. It was placed under the hull and a door under the engine was opened. The heat and smoke of the engine was flowing thru the engine compartment, warming it up.
The V-2-34 was a new engine, which had a negative impact on the performance of the T-34. The engines produced during the first years and until about 1943, didnít come with a lifetime as expected. Normally, the engine should be able to run for 100h without issues. But due to material and quality issues the engines often didnít came that far. Continuous improvements during the war increased the life time of the engine constantly to values of 300h and beyond.
One has to keep in mind that the complete manufacturing was shipped behind the Urals in a couple of weeks, which is a masterpiece on its own.
copy and paste from here V-2/6/12
Old 12-11-2013, 10:18 PM
ogre's Avatar
the 'Duracell Project'
while this has nothing to do with the russian v12 engine you asked about...
i found this 30 cylinder tank engine in the dodge museum in auburn hills michigan
five 6 cylinder flat head motors, all with separate ignition, induction and fuel systems into one gear driven output shaft
the plaque said it was designed for a tank.
Old 12-12-2013, 12:03 AM
evolvo's Avatar
Maybe this is what their talking about
Old 12-12-2013, 04:17 PM
Wiki Edits: 31
Russian engineering isn't always understandable from an American standpoint..
I have a Mosin Nagant 91/30 which the iron sights go to 2k meters. Nobody could ever make that shot with that gun
Old 12-13-2013, 01:10 AM
Originally Posted by ogre View Post
I found this 30 cylinder tank engine in the dodge museum in auburn hills Michigan
I was playing around with the idea of 30 and 40-cylinder 5-bank engines when I was in high school, so it's interesting to me that such an engine was actually built.
Of course, in a tank, you're not too worried about weight; and I've heard that the twin Cadillac set-up in a Sherman had to have the throttles synchronized just right or the slow engine wouldn't pull, so a bigger single engine would be simpler to tune
Old 12-13-2013, 07:46 AM
Banned
isn't that how most rotary airplane engines crank and rods are, some off the rod of another cyl.
Old 12-13-2013, 10:32 AM
evolvo's Avatar
http://www.youtube.com/watch?feature...&v=z4Dg7JuH-48
Very similar but the photo in my previous post is from a V configuration diesel.
Body work, how to make it perfect? slicked Hotrodding Basics 10 02-26-2012 01:04 PM
How can i make this alternator work? scapegoat Electrical 20 05-29-2010 09:07 AM
Any Ideas on how to make this work well dizzle217900 Hotrodders' Lounge 16 03-08-2010 02:27 PM
can't make it work!!!!!!! peter406 Engine 10 03-09-2009 06:10 AM
NO VACCUM, how to make it work? Augusto Transmission - Rearend 3 06-29-2006 06:50 PM
