Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Howe hydraulic t/o bearing adjustment Q...
Old 03-27-2013, 05:55 PM
aisr aisr is offline
I use the same hyd tob, i make sure there is at least 1/16" clearance to allow for disc wear. Too much clearance and the clutch might not disengege enough, especially if your disc has a marcel. The bearing will only retract as far as the PP fingers push it, adjusting the pedal/pushrod won't cause it to retract any farther.
