Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Howe hydraulic t/o bearing adjustment Q...
Old 03-27-2013, 08:48 PM
NastyRat NastyRat is offline
Brg. Set-up
Basic set-up starts by Compressing Brg. then shim to .150 clearance. When it has been bled out the BRG. will always be in contact with clutch fingers. As the clutch wears the .150 clearance will not bottom out the BRG. and will allow for full clutch engagement. This set-up works for all HYD BRG.
