Scat9000 crank scat pro comp I beam 7/16 screw, icon forged flat tops, 11.1 w/64cc heads, this is a 383 stroker the rods are 6", my question is what type of head to use with my setup its going to be a bracket motor,I already have a .500/.500 246@.050 302 advertised flat tapet cam I plan on using. Thank you all , any info appreciated
I've heard good things about Dart heads. But if you're on a budget a lot of guys use the Patriot freedom series 800 bucks ready to run is hard to beat.
I like the patriots. Same specs as the more expensive brands. Only reason they're cheaper is because you're not getting the big name that goes witht the higher cost pieces.
Check out the prices on these heads. RHS 12056-01 HYD flat tappet .560 lift, 220 intake runners, assembled. RHS 12060-01 HYD flat tappet .560 lift 235 intake runners, assembled same price. IDK if your camshaft is large enough for the 235's. RHS Small Block Chevy heads - Competition Components
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
