-   -   how's my 383 build going?? (http://www.hotrodders.com/forum/hows-my-383-build-going-222895.html)
7178Chevyman 08-14-2012 04:14 PM
Scat9000 crank scat pro comp I beam 7/16 screw, icon forged flat tops, 11.1 w/64cc heads, this is a 383 stroker the rods are 6", my question is what type of head to use with my setup its going to be a bracket motor,I already have a .500/.500 246@.050 302 advertised flat tapet cam I plan on using. Thank you all , any info appreciated
bigdog7373 08-14-2012 04:17 PM
With that compression i'll assume it's a race engine. Do you already have the parts?
7178Chevyman 08-14-2012 07:19 PM
Yes I lack the heads and intake, I'm just not sure about what head to use
bigdog7373 08-14-2012 07:29 PM
I've heard good things about Dart heads. But if you're on a budget a lot of guys use the Patriot freedom series 800 bucks ready to run is hard to beat.
ap72 08-14-2012 08:05 PM
Procomp 210's, buy them bare, assemble and check everything yourself. Clean up the casting and bowl area.
if you have the money large port vortec heads are great too.
vinniekq2 08-14-2012 08:43 PM
for ar ace engine,buy the heads first then match the cam to the head flow numbers.
What bracket is your car in? what kind of car?
bigdog7373 08-14-2012 08:46 PM
He already has the cam i think.
Op can you give us a link to the cam specs?
7178Chevyman 08-14-2012 08:54 PM
The cam is crane energize .500/.500 valve lift 246@.050 302 adv. Rpm range 3500-6500, I have been looking hard at patriots
bigdog7373 08-14-2012 09:16 PM
I like the patriots. Same specs as the more expensive brands. Only reason they're cheaper is because you're not getting the big name that goes witht the higher cost pieces.
7178Chevyman 08-14-2012 09:54 PM
That's what I thought, now my only concern is will I have piston to valve clearance using a 2.08 valves?
cdminter59 08-14-2012 10:03 PM
heads for 383 chevy
Check out the prices on these heads. RHS 12056-01 HYD flat tappet .560 lift, 220 intake runners, assembled. RHS 12060-01 HYD flat tappet .560 lift 235 intake runners, assembled same price. IDK if your camshaft is large enough for the 235's. RHS Small Block Chevy heads - Competition Components
