how's my 383 build going?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-14-2012, 04:14 PM
Scat9000 crank scat pro comp I beam 7/16 screw, icon forged flat tops, 11.1 w/64cc heads, this is a 383 stroker the rods are 6", my question is what type of head to use with my setup its going to be a bracket motor,I already have a .500/.500 246@.050 302 advertised flat tapet cam I plan on using. Thank you all , any info appreciated
Old 08-14-2012, 04:17 PM
bigdog7373's Avatar
Of course it's fast
With that compression i'll assume it's a race engine. Do you already have the parts?
Old 08-14-2012, 07:19 PM
Yes I lack the heads and intake, I'm just not sure about what head to use
Old 08-14-2012, 07:29 PM
bigdog7373's Avatar
Of course it's fast
I've heard good things about Dart heads. But if you're on a budget a lot of guys use the Patriot freedom series 800 bucks ready to run is hard to beat.
Old 08-14-2012, 08:05 PM
How fast is fast enough?
Procomp 210's, buy them bare, assemble and check everything yourself. Clean up the casting and bowl area.
if you have the money large port vortec heads are great too.
Old 08-14-2012, 08:43 PM
vinniekq2's Avatar
for ar ace engine,buy the heads first then match the cam to the head flow numbers.
What bracket is your car in? what kind of car?
Old 08-14-2012, 08:46 PM
bigdog7373's Avatar
Of course it's fast
He already has the cam i think.
Op can you give us a link to the cam specs?
Old 08-14-2012, 08:54 PM
The cam is crane energize .500/.500 valve lift 246@.050 302 adv. Rpm range 3500-6500, I have been looking hard at patriots
Old 08-14-2012, 09:16 PM
bigdog7373's Avatar
Of course it's fast
I like the patriots. Same specs as the more expensive brands. Only reason they're cheaper is because you're not getting the big name that goes witht the higher cost pieces.
Old 08-14-2012, 09:54 PM
That's what I thought, now my only concern is will I have piston to valve clearance using a 2.08 valves?
Old 08-14-2012, 10:03 PM
heads for 383 chevy
Check out the prices on these heads. RHS 12056-01 HYD flat tappet .560 lift, 220 intake runners, assembled. RHS 12060-01 HYD flat tappet .560 lift 235 intake runners, assembled same price. IDK if your camshaft is large enough for the 235's. RHS Small Block Chevy heads - Competition Components
whats better 400 crank or a 383 crank in a 350 sbc when trying to build a 383? onlychevy Hotrodding Basics 14 12-28-2012 07:27 AM
383 build turbofirebird350 Engine 3 04-11-2011 06:25 AM
383 build tom penicaro Engine 1 02-24-2006 03:17 PM
383 build HELP!!! bobbypantera Engine 11 05-30-2005 09:10 PM
How to build a 383 70 nova Engine 3 10-04-2003 07:17 AM
