Hows my gear pattern look? 9" - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2012, 06:38 PM
Mach1460's Avatar
Last journal entry: Project 92' Eddie
Working on my gear swap. I previously set up my 4.33s (they were brand new and free from my brother) but were way too much for steet use so im going to a more street friendly 3.25 in my 9inch. Heres some pics of my pattern I think it looks pretty good but hopefully some of you pros might just give me your opinion. I did the 4.33s my self even though they only ended up with 5-600 miles on them they didnt make any noise and they held up behind my 532BBF. So I at least like to tell my self i know what im doing
My backlash according to the markings on the ring gear are supposed to be at .008 I have checked in 10 different spots and im at .0085 to .009 should I try to adjust or leave it be??? Thanks!!!!!
ID:	64402   Click image for larger version
Old 03-28-2012, 06:40 PM
Mach1460's Avatar
couple more pics
ID:	64404   Click image for larger version
ID:	64405   Click image for larger version
Old 03-28-2012, 11:35 PM
rick 427's Avatar
Last journal entry: 33 WILLYS
Pattern looks good to me, best I can tell from the pics....I like .009-.011 on street gears,so IMO,you're good enough there too...One question for conversation sake,do you check the wipe with a load,or no load, on the pinion flange?
Old 03-29-2012, 04:05 AM
Mach1460's Avatar
I use a old soft sanding block to hold pressure on the ring gear. Then I'll put a drill on low and turn it a few times each way. Seems to lay down a readable pattern
Old 03-29-2012, 07:05 AM
rick 427's Avatar
It sure did...looks nice
Old 04-08-2012, 03:22 PM
Looks great
That looks great. Just make sure you get enough carrier bearing preload by using a proper tool of some sort to apply 150+ft#'s of torque to the side adjusters. A huge cresent wrench with one 1/4" holes in each jaw to hold hardened roll pins works well and the wrench is reasonable from HF.
Yukon_Installation_Instructions.pdf
Old 04-08-2012, 03:31 PM
Mach1460's Avatar
I use a otc brand spanner wrench designed for Toyota timing gears I think. It has screw in pins for different sized holes and also has a 1/2 square Hole for using with a 1/2 tq wrench
I can get the part number if anyone is interested I use it for all kinds of automotive projects. But I have never used it on a Toyota timing gear haha
Old 04-09-2012, 08:57 AM
Sure why not; and a picture.
Old 04-09-2012, 01:26 PM
Mach1460's Avatar
Heres the tool, Works great in a lot of situations with all the different "pins" Since its adjustable with the 9/16" nut in the center it works great for tightening down harmonic balancer bolts with an extention, i cant see how it wont fit anything any car guy would need it for (maybe not some big diesel stuff)
ID:	64679   Click image for larger version
ID:	64680   Click image for larger version
ID:	64681   Click image for larger version
Old 04-09-2012, 06:48 PM
That is helpful -- Nice tool! Thank you
Just be aware the torque reading on a tq wrench will be delivered to the spaner multiplied from the wrench reading depending on the angle and total length of the wrench system relative to the tq wrench itself.
Old 04-10-2012, 08:31 AM
Mach1460's Avatar
absolutely, sometimes a guy just has to go by feel
Got my new gear, need a pattern check 96lt4c4 Transmission - Rearend 18 10-25-2011 09:41 AM
Gear pattern check Coolball Transmission - Rearend 26 06-13-2011 12:18 PM
Ford 9" Gear Pattern johnsongrass1 Transmission - Rearend 2 04-23-2011 11:24 PM
Gear pattern or measurements? Harold56 Transmission - Rearend 1 09-26-2007 09:04 PM
Is my rear end gear pattern ok? Warrant Transmission - Rearend 1 04-22-2007 09:34 PM
