howto remove upper n lower control arm bushings???
i just recieved all my urethane bushings, boot, intermediate, tie rod ends etc etc, from summ it. i have everything removed (coil springs scary) and for the first time on a build everything was going easy until... upper and lower controll arm bushings! they say to goto a shop n have em pressed, but summit tech guy said torch rubber out an punch metal sleeve out. but i know u guys know best! i dont have a torch but we drilled/pulled out 1 bushing but sleeve is in there good. any advice is helpful theyll tow away my monte if its not presentable soon!
I have done it by drilling the rubber out and getting all that out of the way. Then I took a cold chisel and carefully demolished the outer bushing sleeve. An air chisel can be helpful too.
Good luck. Don't let um tow your Monte!
I've used the burn-the-rubber method many times. It's smelly, smokey, and messy, so do it outdoors over a metal bucket. I've been told (but not tried) that a roto-zip tool removes the rubber just as easily without the mess.
thanks guys im gonna start bustin on it for a few hrs before work. so the idea is to slot if not cut the sleeve all the way through?
I used a bench vice and a couple pieces of pipe that I cut as spacers. Takes a vice that opens up 6" or more to do it this way tho.
I also found that driving the metal shell out of the middle (that the bolt goes through) loosens things up enough to just push or pull the bushing out almost by hand. Be careful about chiseling out the shell. Some bushings like Energy Suspension require that you REUSE the old shells. Also those shells are pressed in really tight, a bench vice almost cant press those shells in after they are out. I |
| Heid's Narrowed upper & lower control arms | fat40 | Suspension - Brakes - Steering | 1 | 01-30-2007 01:20 PM |
| Upper Control Arm Axle Bushings Removal | Steve karch | Suspension - Brakes - Steering | 3 | 09-05-2005 10:39 AM |
| upper control arm axle bushings, remove/install | ss396si | Transmission - Rearend | 1 | 02-16-2005 05:57 PM |
| average labor cost for replacing upper/lower arm bushings? | 72Nova | Suspension - Brakes - Steering | 1 | 02-02-2003 06:32 AM |
| Narrowed upper & lower control arms | Michael Bean | Suspension - Brakes - Steering | 1 | 12-29-2002 03:40 PM |
