Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hp body upgrade
Thread: Hp body upgrade
Old 05-17-2013, 02:49 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
Define: too rich at idle.... How are you determining this?
Are the idle mix screws active? can you stall it by turning in the idle mix screws?
How many turns out are the idle mix screws when the idle is set correctrly, using a vacuum gauge.?
The float height has a minor effect on the whole fuel curve.
