Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hp body upgrade
Thread: Hp body upgrade
Old 05-17-2013, 03:59 AM
bygddy bygddy is offline
Proud LOSER
Originally Posted by F-BIRD'88 View Post
Define: too rich at idle.... How are you determining this?
Are the idle mix screws active? can you stall it by turning in the idle mix screws?
How many turns out are the idle mix screws when the idle is set correctrly, using a vacuum gauge.?
The float height has a minor effect on the whole fuel curve.
Mixture screws are app 1 turn out, maybe 1 1/4. Yes they are responsive and will shut the car off when dialed too far in. Using a vacuum guage I'm showing a steady 15hg in drive at 650rpm.
By "too rich" I'm saying it makes your eyes water anywhere near the back of the car, and very very minor dark smoke at idle at the tailpipe.
Your Canadian, you know how some mornings its just cold enough to very lightly see your exhaust when the car is warming up, that's what its like.
Yes I nknow I need a wideband but can't make that happen until next month.
