Hp body upgrade - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 05-26-2013, 12:20 PM
Proud LOSER
OK, got a new vacuum guage, reset transfer slots front and rear, started over with mixture screws,
Vacuum is 18 in park, 15 in gear, mixture screws are very sensitive to tiny changes, they are both a little over 1.5 turns out.
Idle seems stable and has snappy response. Still very smelly exhaust, no smoke at idle now.
Going to go drive it now and see what i have.
Fine, I concede, I will pick up tune up parts this week lol....see if it helps.
  #32 (permalink)
Old 05-26-2013, 04:21 PM
Proud LOSER
I give up.....runs perfect, it could pass for fuel injection at this point, its snappy everywhere, no bogs or stumbles and pulls clean from every rpm......
Smokes and smells....behind me, cruising speed, its clean....but idling in the lane way, smokes, accelerating, smokes....def dark, def fuel....
I give....
  #33 (permalink)
Old 05-26-2013, 08:18 PM
F-BIRD'88's Avatar
Yada Yada Yada
Whats the tune up on the carb now?
Smoke in exhaust at idle...are you sure there is not something blocking one of the idle wells in the metering block
Raw un emulsified un mixed fuel at idle or something.
Ignition issue?.... very odd...
  #34 (permalink)
Old 05-26-2013, 08:41 PM
Proud LOSER
70/80
75/36/36/76
36/36/36/36
Transfer slots squared
Now sitting on my shelf....
Got pssd off and threw on my 650DP and will see how that works in the morning on my way to work.
70/76
Jet extensions
idle is much snappier, mixture screws 1.5 turns out.
Haven't driven it till the morn.
If it isn't any better then I will have to go deeper I guess.
Thanks for the help with it and I will report back tommorow.
Dave
  #35 (permalink)
Old 05-27-2013, 06:03 PM
Proud LOSER
Stpd Carb, stupid tuner.....(me)
650 works fine....no smoke, pulls hard....
For now the 750 sits.....will worry about another time.
Thanks again F-Bird....appreciate the help.
Dave
If you do not want to register, fill this field only and the name will be used as user name for your post.
g body motor upgrade, gen1,lt, or ls? ol'wood75 Hotrodding Basics 13 04-17-2009 11:15 AM
Cheapest Rear end Upgrade for G-Body GM chevy_power427 Transmission - Rearend 9 08-20-2008 08:10 AM
3rd Gen F-body rear discs on 65 A-body 12 bolt? smallblocker2 Suspension - Brakes - Steering 7 03-22-2006 12:51 AM
mopar A body disc brake upgrade 74 swinger Introduce Yourself 2 12-04-2004 11:14 PM
Mopar A-Body Brake Upgrade BigBlockBabe Suspension - Brakes - Steering 2 02-12-2003 06:59 AM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
