HP Estimate. 360ci. - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2005, 12:53 AM
Sagacious's Avatar
Do you feel like we do?
HP Estimate. 360ci.
i was wondering if anyone could give me an educated estimate on the HP i would be making with this motor combo i'm building.
350 SBC bored .60 over.
Edelbrock RPM AirGap with 1'' wood resin spacer
Edelbrock 600cfm, rejetted (2 stages richer)
10:1 compression
Comp cams XE268 (.477/.480)
1.5 full roller rockers
1 5/8 headers, 2.5'' exhaust with H pipe, Flowmaster 50 series.
Heads are 2.02/1.60, screw in studs and guideplates.
Dyno2000 says im at 380hp and nearly 400ft/lbs torque.
does this seem too high or is it accurate? hopefully someone has a similar setup.
thanks.
Old 01-27-2005, 02:13 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
hp
between 350 and 380. Carb should be a 650 cfm.
