HP Estimate? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2005, 12:16 PM
Mike_82's Avatar
HP Estimate?
I have a 360 SBC that im putting in my street stock. i was just wondering if i could get a HP/TQ estimate, and possibly if i should change my cam and intake.
350 SBC bored .60 over.
Edelbrock Torker 2 intake
Holley 650 cfm carb
11:1 comp.
Crane Energizer 302. .500" lift, 246 degrees duration@.050". 106 lsa
full roller rockers (cant remember ratio)
1 3/4 headers, 3" exhaust from header, about 2 ft long, to gutted glasspacks.
Heads are '66 Camel Hump 2.02/1.60, fully ported, screw in studs.
Im thinking about getting a Victor Jr. or equal intake, and an Isky 284 mega cam. is that a good idea? im wanting to step down in duration a bit because i think 246@.050" is a bit to much for it.
Thanks.
Old 01-31-2005, 03:42 PM
Tazz
just a guess of course....
I'd say an easy 300hp there guy er Mike!!
Tazz
Rat Rods Rule!
Old 02-03-2005, 09:04 PM
lluciano77's Avatar
You will get more top end out of a 700 to 750 carb.
If you have a 4777 Holley, the idle circuit is probably going to be too lean.
Old 02-03-2005, 11:42 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
perfect package
I love that cam. I put one in my 400. I would say without knowing your runner size. You are pushing 350 hp. If you have good runners maybe 375.
I built the same package but I used the perf/rpm heads and a .477 comp cam. I ran 13.3 in a 3800 lb car. It takes 375 hp to do that.
Old 02-07-2005, 09:06 AM
You should be in the 375 hp range with 400 ftlbs.
Your weak link is the cylinder heads and intake manifold. Get a set of ARF's and a performer rpm intake and pick up 50 hp!
Trash the glasspacks.
Your cam duration is not that much. However, it all depends on car weight, diff gears, transmision, and convertor you are using.
I ran a setup like that with 200cc dart iron eagle heads, rpm intake, 750 Holley, 5 speed trans, 3.90 gear, in a 2950 lb car. It ran 120 in the 1/4 mile and 135 with 150 hp N20.
Old 02-10-2005, 11:59 PM
Scorpio Shaping Flow's Avatar
New Member
Carb's OK
The carb's good for 500HP easy, so it's ok in a 360 pushing about 400+HP. The cam's ok enough, because your compression is at 11-to-1 anyway. The heads are perfect. In fact, the engine could easily take adavantage of a cam with .550-.570" lift and 250 degrees duration at .05" inch lift for closer to 450-470HP.
