HP estimate new 468 comb - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2013, 11:00 PM
I know there are a few calculators out there, was wondering if someone would mind plugging in my numbers for a HP estimate
468
10.0 to 1
820 ovals, 2.19, 1.88, pocket ported with a bit of runner cleanup
lunati hyd roller, 241/249 @ 50
2 inch headers
air gap
850 demon
80 firebird with a 3000 convertor and 3.42 gears, partially stripped with a 6 pt roll bar. No et yet but a bit of street time. Wow does this thing pull.
It has a cast crank and I have the rev limiter set at 6000. What is max rpm with this crank.
Thanks
Old 05-22-2013, 11:15 PM
Need lift an flow numbers for heads to get in the ball park.
Old 05-23-2013, 12:08 AM
Lift is .625 intake and .625 exhaust
lift int exh
.1 70 72
.2 144 132
.3 208 158
.4 245 176
.5 278 191
.6 284 202
head flow is from a set of 820's with similar work done to them
Old 05-23-2013, 05:54 AM
vinniekq2's Avatar
My 1980 Camaro ran 11.9s with a similar engine with solid flat tappet cam(Z-55). I figured mine was a little under 500 hp
Old 05-24-2013, 02:14 PM
track is late here, a lot of snow this year, look forward to getting out. 11's would be great.
Old 05-24-2013, 04:58 PM
vinniekq2's Avatar
If it doesnt go 11s,its not the engine.
Comb Chamber Design v Total WOT Spark Advance 1965tripleblack Engine 22 02-19-2012 03:52 AM
recommend motor comb. for dodge 360 wagon360 Engine 5 03-10-2009 10:37 AM
TH-350 Rooster Comb - Differences? nova69 Transmission - Rearend 1 08-25-2008 06:11 AM
homey comb wheels steel dragon General Rodding Tech 5 01-28-2007 06:32 PM
what is the largest 15 tire wheel comb for 1970 pont,lemans aaroncre8 Suspension - Brakes - Steering 1 01-09-2005 06:08 AM
