hp guess - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-11-2006, 06:47 PM
Banned
hp guess
okay, I know this spec sheet has holes, but please give it your best guess.
383 chevy
5.7 rods
ported RPM airgap intake
ported stock heads (I don't know the casting numbers) with 2.02/1.60 valves
9.8:1 compression (flat top pistons)
long tube headers
750 carb
HEI (accel componenets
the magic 268 cam with 1.6 rockers
Any ideas to help me get a few more ft/lbs of torque are apprecaited. I Love me some cheap and easy torque.
Old 04-11-2006, 07:13 PM
e-tec 170 heads
your heads are holding you back. i am no expert but i would think those heads are costing you about 100 hp and 75 ft lbs
Old 04-11-2006, 07:24 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
What 268 cam? There are a few out there. Also, the casting number of the heads is located between the rocker studs.
Old 04-11-2006, 07:44 PM
OldSchoolChevy's Avatar
Gotta love the classics
heads=too small
Old 04-11-2006, 08:35 PM
Banned
I know the heads are limiting, but with a really good porting job do you think 400+ hp is possible (flywheel)
Old 04-11-2006, 09:21 PM
Blazin72's Avatar
Wiki Edits: 19
As I mentioned earlier...locate the casting number on the heads, not all heads are the same. Also, Several companies have a "268" cam, which do you have?
Old 04-11-2006, 09:45 PM
Banned
comp cams i think its the xtreme energy series
Old 04-12-2006, 06:31 PM
Rhansen's Avatar
Footbraker
332hp @ 5000
376 lb-ft @ 4000
500 hp small block ? 73monte Engine 14 12-06-2008 01:37 PM
eagle crank hp rating. engineman302 Engine 4 04-10-2005 04:38 PM
260 HP or 290 HP GM Crate motor Iceberg Engine 4 02-26-2005 01:26 PM
A few changes to 540 hp carcraft buildup... what kind of hp loss? guesstimates please elukas Engine 16 08-07-2003 07:54 PM
didn't know where to ask this but HP and TQ relationship? stonedchihuahua Hotrodders' Lounge 11 12-14-2002 03:02 PM
