hp question - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2004, 12:20 PM
hp question
hey guys, just wondering if someone could tell me how much hp my little smally is making...,
got a stock bore 350, zero decked block, .125 domed hyp. pistons
summit cam 214/224 @.50 with1.6 rollers so lift is .472/.496.
edelbrock performer rpm 64cc heads and an edelbrock performer
intake. Cam is installed straight up, and an edelbrock 750cfm carb
crank is steel and rods are 5.7 refurbished with arp bolts.
its all sitting in a 1980 trans am turbo se with a 2500 converter and a 3.42 gear.
thankx in advance
Turbo Terror
Old 12-28-2004, 01:06 PM
GoneNova/406's Avatar
your cam lift is 471/496,yours is a little backward.mine is 472/496 and i like that set up very much.if you go to
www.westechperformance.com
you will find all the engine calculators you need.more info is needed than what you gave but it sounds like a pretty potent set-up.
Old 12-29-2004, 05:29 PM
thanks for the reply gonenova/406.
