In a light car such as your Monza.......the 200 will stand up to more power than you can get the 305 to dish out ..
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
Fantastic! Thanks Deuce, that is just what I was hoping to hear. Eventually I will be putting a 350ci in it but not till winter and then I can move to a TH350. I just wanted to have a little fun with it this summer without spending a lot to get it running a little better than it does. By the way, I am putting a posi in it. That won't cause any trouble will it? Thanks again.
Mike |
Has anyone ever used oone of these kits from Summit for the swap of a TH200 to a TH350?
http://store.summitracing.com/produc...57#largerimage Mike |
I believe that bracket is what you are looking for if you change to a THM350 .As far as the 1977 THM200 the name came from the original design torque capacity of the transmission 200 pounds feet of torque. The 350 was for 350 lbs/ft the 125 was for 125 lbs/ft. The 440T4 and the 700R4 were metric.The 440T4 was 440 newton meters. The 700R4 was 700 Newton meters.
As I recall, the only thing you will need to change from a TH200 to a TH350 is the correct kick-down cable, dipstick and tube, and a vacuum line for the modulator. The mount, linkage, and driveshaft should interchange.
