HP Torque estimate on this 406 SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-12-2010, 06:54 PM
I may be getting this engine in a few days. Do you guys have any estimate of HP and Tq.
GM 400 block, -817 casting, 2 bolt mains with ARP bolts
Bored .030 over, sq decked, align honed, bores honed with TQ plate
Deck height is .014
Scat 9000 series cast crank, 3.75 stroke
Scat 5.7 I-beam rods
Speed Pro 615CP30 hyper, coated skirt pistons, 12.5cc dish
Balanced rotating assembly
Dart Iron Eagle 200cc heads, 64cc chambers, straight plugs
Stage I port job with multi-angle competition valve job
New Ferrea 2.02/1.60 valves
Comp Cam 943-16 springs, retainers, super locks, guide plates, stem seals
ARP 7/16 rocker studs, 5/16 pushrods
Scorpion full roller rockers, 1.5 ratio
Mr. Gasket 5801G head gaskets, .038 thick W/4.190 bore
CR is calculated at 10.4...pump gas friendly.
Crane 118131 billet core Solid roller cam
282/290 adv; 242/250 @ .050
.580/.600 lift w/1.5 rockers
LSA 106; installed at 102
Crower severe duty solid roller lifters w/pin oiling option
Cast aluminum timing cover with cam button
Edelbrock RPM Air Gap intake, #75014 Endura-Shine coated
MSD distributor and 6AL ignition box
Holley HP 750 double pumper carb
Carter Hi-volume fuel pump w/braided hose to carb
Edelbrock 75014 - Edelbrock Performer RPM Air-Gap Intake Manifolds
Speed Pro moly rings, Clevite rod and main bearings
Durabond cam bearings, brass freeze plugs
Mellings standard oil pump
Moroso 6 qt kickout pan w/matching pickup
ARP pump shaft
Old 08-12-2010, 08:13 PM
OLNOLAN's Avatar
Air Dyno
My best guess is 500/500 if all the tuning is done right. But you never mentioned the headers. Important at this HP level olnolan
Old 08-13-2010, 08:34 AM
havent decided on the headers yet, because I dont have the engine in my possession. Im assuming I need something with about 2 inch primaries that dump into some 3 inch exhaust.
Old 08-13-2010, 08:49 AM
my87Z's Avatar
Veteran/Firefighter-Paramedic
all and all it sounds good, one question i would strongly ask before you buy is how old the heads are. DART has had the Iron Eagle line for quite sometime now but about 4yrs ago the revised them and came out with the Iron Eagle Platinum heads these are much better performers than the original Iron Eagle heads, and now DART doesnt even produce the old Iron Eagle heads except for in 180cc all 200cc iron eagle heads are the platinum heads but like i said that didn't take into affect until about 4yrs ago.
the cam sounds good, if you plan on using it as street stip car i might would think about a 800-850CFM (true) double pumper, but if you are just going to drive it on the street the 750 double pumper is just fine. as far as headers go you dont need anymore than 1 3/4" primaries, with a 3" collector, 2.5" exhaust would do fine but i would still probably go with 3" (just cause that's the way i am)
with decent long tube 1 3/4" headers, the Platinum heads (unmodified) and tuned correctly i would est this motor at just 500/500 like the other guy. if the original builder was smart and had some minor porting and cleaning up of the guides and bowls then i would say it could be making 530-550. but if they are the older style iron eagle heads i would est it at 470/480. the platinums makes a big difference.
Old 08-13-2010, 08:56 AM
lg1969's Avatar
Google "Tunnel Ram 406"
My guess is 520hp/ 550ft. lbs.
Old 08-13-2010, 09:25 AM
I would say 500hp/535lbft.
cam is a little off. darts iron eagle heads flow well on the exhaust side so they don't need more duration on the exhaust lobe when using headers.
And why use 106 LSA? 110 would work better. 106 makes the idle rougher and the cylinder pressure go up. 10.4:1 cr is high for a cam with only 282 degrees duration (seat to seat) and the 106 LSA isn't helping. Plus darts flow well on the intake and don't need as much valve overlap to help fill the cylinder. I think you are going to have detonation issues with that setup.
I would a cam with around 290/290 degrees with 110 lsa.
Old 08-14-2010, 01:28 PM
I did get the engine today and Im pretty sure the heads are the older Darts, but they have been reworked as listed below.
The engine was built and assembled by a very reputable machine shop in Hiram GA, but it has not been ran yet. Hopefully no detonation issues.
Old 08-14-2010, 04:22 PM
OLNOLAN's Avatar
Bad *** 406
Hey Man, Sounds like a badazz 406 combo to me! I'm not gonna critize your combo, sounds like its gonna be a real peaky combo with the tight LSA and the advanced cam timing. Only problem I ever had with engines like this was hard to start and hard to warm up. When it's ready, it's gonna be a stump puller. Likely to 60 ft. good if you can hook the tires, Whats it in? olnolan
Old 08-14-2010, 04:38 PM
Its not in anything as of yet. I got this in a trade from a guy that sold his car while this motor was in the machine shop. I have a 67 malibu in rough shape that may get tubbed and caged and converted to a strip car, unless I find another roller pretty soon. Im not a engine guru by any means so Im just looking for advice. I may end up selling the engine as well if I dont find the motivation to build a car. Im neck deep in a 67 SS Chevelle restoration at the moment thats taking up all my time.
Old 08-15-2010, 08:16 AM
I calculated a 8.5:1 dcr (dynamic compression ratio) with your combo. 10.4:1 scr (static compression ratio), 282 seat to seat cam, 106 lsa, installed at 102, 5.7 rod, 3.75 stroke.
7.5 to 8.0:1 dcr is best for pump gas and iron heads.
a cam with 110 lsa and 290 degree of duration (seat to seat ) will lower the dcr to round 7.75.
even retarding the cam you have (installed "straight up") will lower the drc to 8.25:1
Old 08-15-2010, 06:16 PM
If I use this engine it will probably be in a car built for the strip, and only run a few times a year at that. So if I must, then I will feed it race fuel. Im working on a street car right now, so I dont really need another street engine. My primary goal may end up being to sell the motor.
Old 08-15-2010, 06:35 PM
my87Z's Avatar
i'm not saying that this is wrong at all cause it is pretty much true, but i am running a 385cid engine with 10.3:1 static compression and almost 8.6:1 dynamic compression ratio with iron heads and it can still run on pump gas. it is at the brink and to tell you the truth i always use additive with it as it is just a street/strip car that see's about 1200 miles a year and so far has had about 40 passes on it (it's only been done for a year now). but i have run it on 93-94 octane and i have had no issues. so it can be done.
but also to be honest i put the motor together and took it to be proffesionaly dyno tested and tuned before i ever put it in the car
Old 08-15-2010, 08:03 PM
ericnova72's Avatar
More for Less Racer
I've built very similar engines, it will run just fine on pump gas.
I don't even bother with dynamic compression ratio calculators. Every one you use will give different results for the same batch of parts, which leads me to beleive none of them are very correct. I just let my experience guide me, and I've gone clear into the 11-1+ area with no problems on pump fuel. I pay more attention to quench and chamber shape.
Old 08-15-2010, 08:26 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Just a quick FYI- you don't need headers any larger than 1-3/4" for this engine. 1-7/8" could possibly make a bit more peak, at the expense of losing power lower down in the power band. If it were me, it would get 1-3/4" primaries. Nothing wrong w/3" exhausts, w/an "H" or "X" connecting the two sides after the collector and before the mufflers. Put the mufflers as far rearward as possible, if you run mufflers.
Old 08-19-2010, 08:50 PM
Thanks for the info guys. Good stuff
350 SBC How Much HP? Top End Upgrade kgpearce Engine 8 05-28-2008 04:33 PM
HELP!!! I Want 2 No How Many Hp Does My 350 Sbc Have...?????????? jkingof9561 Engine 2 04-29-2008 12:11 PM
Building a SBC to rev to 8k, and have power Andyrew Engine 52 04-17-2006 12:46 PM
350 sbc how much hp 54chevy22 Engine 2 08-17-2005 01:43 AM
Torque & HP for 355 SB Chevy bigjoedo Engine 7 04-17-2002 10:11 AM
