-   -   HP / Tourqe estimate (http://www.hotrodders.com/forum/hp-tourqe-estimate-220511.html)
prostcelica 06-13-2012 08:26 PM
Hey Guys.
What do you guys think would be the estimated HP and tourqe on the combo below. If i have missed providing any required info to make an accurate estimate please let me know.
Thanks in advance
SBC 350 .030 Stock internals
10:1
AFR 180cc heads
comp magnum 270 cam (duration 224 at .50 int/exh.47 lift)
Edelbrock Rpm air gap
Holley 670 street avenger
1 5/8 headers / Magna flows
prostcelica 06-13-2012 08:29 PM
FORGOT!!!
1.6 roller rockers
454C10 06-14-2012 04:33 AM
looks like combo 13 on ryan's small block dyno website.
http://www.ryanscarpage.50megs.com/combos1.html
It made 430hp at 5000 rpm and 435 ftlb at 3800 rpms. Also says the data was from the ARF website so it may be on the high side.
my87Z 06-15-2012 08:51 AM
i think the 430/435 estimate from the website is a bit high
i would guess around 400-410hp and 415-420tq (not a bad little street motor)
now if you were willing to go with a hyd roller cam set up with a similar duration but yet closer to .550", and spend a little extra money on having those heads cleaned up just a little bit, i think those numbers could be closer to 440hp/440tq
AutoGear 06-15-2012 01:27 PM
400 HP; 400 LBFT approx
