HR.com lawnmower problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2005, 10:03 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
Here's the beef:
Starts all the time, real fast and good, when cold.
After running for a while it likes to quit on me, and sometimes when i put it down to idle after it's been running for a while (needs carb tuning for that)
But- about half the time when I go to restart it, it refuses to start, crank over, etc. But with the ignition switch on the headlights work. The other half of the time it usually starts instantly, and the times it doesn't I think I flood it or something stupid I did .
I am thinking this is the safety switch that is connected to the brake since it will start once in a while without having to apply the brakes, and other times the switch does it's job.
I'm just asking for opinions here, pics are in my gallery for a similar problem about the entire electrical system not functioning at all (the + wire came off the ammeter of all things )
thanks,
matt
Old 06-12-2005, 10:10 PM
docvette's Avatar
Wiki Edits: 12
bypass
Doc here,
Simple, just bypass the switch for awhile and see if the problem reoccurs, If not...replace the switch....
What kind of system is this? Didn't see any pics in your Gallery..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 06-13-2005, 03:51 PM
Wiki Edits: 7
what kind of system, It's electrical, the pedal pushes on a pushbutton type switch, tractor is circa 1971-1973. It's in a sub-gallery so I'll post a direct link to that machine (fyi my dad made me put a muffler on it and I haven't updated pics since a briggs muffler isn't anything cool other than making it so I don't need earplugs but this is off subject)
here's pics http://hotrodders.com/gallery/showgallery.php/cat/3120
but none show the switch, jumping it is self-explanatory, pull the wires out and fasten together and see how the problem is... I might go and do this tonight yet, and I'll keep ya posted.
-matt
Old 06-14-2005, 11:39 PM
wow, i have never seen a mower with a sideshaft engine.....
try rebuilding the carb, on my old gokarts, a dirty carb would keep it from starting when hot......
Old 06-15-2005, 10:48 AM
Wiki Edits: 7
/\the little tractor dates back to the early 1970s, even light duty stuff was pretty good back then.
I rebuilt the carb last year, *first carb rebuild* and if the switch doesn't fix it then I'll do the carb again, being a first timer I might have done something wrong.
I'll get working on it June 16
http://www.hotrodders.com/showthread...206#post468206
Old 06-18-2005, 02:15 PM
Wiki Edits: 7
it runs great now, thanks guys
Old 06-18-2005, 06:32 PM
docvette's Avatar
Wiki Edits: 12
Fix??
Doc here,
Sooooo...What was the Fix???
Doc
Innovations
SBC problems.. Its slow Andyrew Engine 80 08-18-2007 09:04 AM
Got my HR.Com Security System cboy Garage - Tools 22 05-28-2005 06:15 PM
Engine Problems, Oil related or coincidence only? Francis Engine 1 05-12-2004 07:56 AM
SBC 350 Crank Balancer Problems bjam2 Engine 8 05-04-2004 08:36 PM
