Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - hub assembly breaking instantly 95 k1500
Old 06-26-2012, 09:11 PM
S10 Racer's Avatar
S10 Racer S10 Racer is offline
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Originally Posted by Catatonic21
i have now broke 4 hub assemblys
after breaking the 3rd hub i replaced
upper/lower ball joints
upper/lower control arm bushings
tie rod end
i started out with the cheapo "house autozone hub" my 4th hub was the best i can buy from autozone
i am running maximum offset rims with 31x10.50 r15s
the only thing i can think is left is something wrong with my CV axel with the nut fully tightened on the hub there is maybe 1/4 of play in the hub assembly
just looking for advice or if anyone else has had the same problem everyone just tries blaming my tires when before this i had a 94 running 33x14.50 on maximum offset 12 inch rims with 1 inch wheel spacers and never broke a hub in my life i had the truck for 500k miles
There should be no play in the axle. The axle is what holds the hub together so it should be tight. Most hubs are made in China now so theres the first problem. Try to find a better brand somewhere else. Find out why the axle is not tightening up correctly.
