Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - hub assembly breaking instantly 95 k1500
Old 06-26-2012, 10:26 PM
66GMC's Avatar
66GMC 66GMC is offline
Get in, sit down, hang on
Last journal entry: Cab Removal
Yep, I try to suggest using the brand name hub assy's every time.
Sure the offshore stuff is cheaper, but you'll never get much representation or consideration from your suppliers manufacturer ... and in a case where you've had 4 failures, it would be nice to have someone to ask for help. Not necessarily "free parts" ... but at least the benefit of their expertise and advice.
I checked that application and the correct SKF (NAPA) part # is BR930346.
I have attached a screen-print of the available dimensions from SKF's online catalog.
Your first 3 were Duralast #DL515024 , and the last one was Timken #SP550307 ... correct?
Timken is a well-repected mfr, so if that is the correct PN, I'd ask Autozone to call the tech line on your behalf, and ask them if they've had any issues ..or ideas?
Last edited by 66GMC; 06-26-2012 at 10:29 PM. Reason: added hyperlink for SKF catalog
