-   -   hub assembly breaking instantly 95 k1500 (http://www.hotrodders.com/forum/hub-assembly-breaking-instantly-95-k1500-221040.html)
Catatonic21 06-26-2012 09:02 PM
i have now broke 4 hub assemblys
after breaking the 3rd hub i replaced
upper/lower ball joints
upper/lower control arm bushings
tie rod end
i started out with the cheapo "house autozone hub" my 4th hub was the best i can buy from autozone
i am running maximum offset rims with 31x10.50 r15s
the only thing i can think is left is something wrong with my CV axel with the nut fully tightened on the hub there is maybe 1/4 of play in the hub assembly
just looking for advice or if anyone else has had the same problem everyone just tries blaming my tires when before this i had a 94 running 33x14.50 on maximum offset 12 inch rims with 1 inch wheel spacers and never broke a hub in my life i had the truck for 500k miles
S10 Racer 06-26-2012 09:11 PM
tie rod end
There should be no play in the axle. The axle is what holds the hub together so it should be tight. Most hubs are made in China now so theres the first problem. Try to find a better brand somewhere else. Find out why the axle is not tightening up correctly.
66GMC 06-26-2012 10:26 PM
1 Attachment(s)
Yep, I try to suggest using the brand name hub assy's every time.
Sure the offshore stuff is cheaper, but you'll never get much representation or consideration from your suppliers manufacturer ... and in a case where you've had 4 failures, it would be nice to have someone to ask for help. Not necessarily "free parts" ... but at least the benefit of their expertise and advice.
I checked that application and the correct SKF (NAPA) part # is BR930346.
I have attached a screen-print of the available dimensions from SKF's online catalog.
Your first 3 were Duralast #DL515024 , and the last one was Timken #SP550307 ... correct?
Timken is a well-repected mfr, so if that is the correct PN, I'd ask Autozone to call the tech line on your behalf, and ask them if they've had any issues ..or ideas?
Catatonic21 06-27-2012 12:17 AM
yeah your right kinda first one was gm stock then 2 duralast now a timken broke
S10 Racer 06-27-2012 12:20 AM
Can you post a picture of the hub & your truck? It would give us a better idea to help.
66GMC 06-27-2012 12:20 PM
Another thought ...
1 Attachment(s)
Another thought occurred to me.
1988-1994 K1500 used a different hub assy. (BR930094)
It's not uncommon to see a "carry-over" from the old part into the following year.
GM uses the term "first design" and "second design" on occasion.
See atached PDF for attributes for this P/N.
