huge backfires through carb - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-07-2013, 08:56 PM
I recently decided to put together a sbc I had laying around. I used a lightly used crate short block and put 2.02 heads on it. Cant get it to run and I am getting the loudest backfires I have ever heard! Ive checked my ignition timing and firing order on my hei distributor numerous times and they are correct. I know im not 180 off because I found tdc with the valve cover off and verified I was on the compression stroke with my finger in the plug hole. Ive checked compression and they are at 150 in all cylinders. When I take the carb off I noticed there was a lot of standing fuel in the intake. Swaped my Holley for a Edelbrock off a running vehicle and I still have the same problem. I am going crazy over here Can someone please help me??
Old 02-07-2013, 09:07 PM
If the ignition wires are in the correct firing order is it possible that the distributor is off 1 tooth, thereby throwing the firing order off. It sounds like each cylinder is not burning the fuel causing the backup in the intake manifold. Or possibly the wrong plugs in the heads?
The Following User Says Thank You to cadillacdave1 For This Useful Post:
pilona42 (02-07-2013)
Old 02-07-2013, 09:09 PM
Are you suggesting a hotter plug? Im sure Im not a tooth off!
Old 02-07-2013, 09:34 PM
DoubleVision's Avatar
If your positive the timing is correct, then that leaves a few things to check.
For starters I'd check the voltage going to the HEI, it must get a 12 volt signal. If it gets less it will run, but backfiring and running like crap will be the result. Next I would check the spark, if the spark is blue it's good, if it's yellow it's weak. Next check the valve adjustment very carefully, if any are too tight it will cause this same thing. Also when you put this engine together did you match the balancer to the timing tab? If you used a 12 o'clock balancer and a 2 o'clock tab then the timing is way off.
If all these things check out good then the last thing I would suspect is the timing is off on the chain.
You also may want to check and make sure it doesn't have a major vacuum leak.
Old 02-07-2013, 10:07 PM
I am running a wire straight from the battery to the dist. I also purchased new wires, plugs, cap, rotor, and coil. My latest suspicion is my heads. Is it possible I am leaking air from the compression stroke through the intake valve? (thought that would explain the excessive fuel in the intake) I did not use valve grinding compound and lapping tool when installing my valves. Does my even compression rule this out?
Old 02-07-2013, 11:49 PM
Got her licked!! Im a idiot! Set my cam gear at 6 o'clock and crank at 12 with #1 at tdc. Cam is 180 off. Thanks to all who responded
Old 02-07-2013, 11:53 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Just reset the distributor 180 degrees from where it is. That will put everything as it should be, no need to remove the cam!
backfire through carb, sbc
holley carb backfires threw carb talleyho Engine 63 01-04-2016 10:43 AM
350 chevy engine backfires thru carb toms1940chevy Hotrodding Basics 8 09-23-2009 07:24 PM
backfires thru carb (truck sits alot) ***? lclark96 Engine 3 09-14-2008 03:00 PM
350 Lopes at idel and backfires out carb. HELP No Butt Engine 18 09-11-2008 08:30 PM
4B roc.carb adjustment and engine purge or small internal backfires 72 chevy elcamino Engine 0 10-13-2002 02:19 PM
