Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Huge bog at 3k
Thread: Huge bog at 3k
Old 02-14-2011, 12:26 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by prettyboyced
I have a 350 l98 heads 270 comp cam 600 edelbrock carb 1405 and if I'm driving at wot around 3-4k i have this huge bog feels like it's running out of gas but it only happens in 2nd and 3rd gear my timing is set at 34 total and the only mods I did to the carb was change primary rods and accel pump
After the bog, how does it run? Strong on out to red line, or not so much.
Does the bog coincide w/the secondaries opening, OR the step up springs lifting the needles? The springs are related to the engine vacuum, so you'll be able to tell if you can set up a vacuum gauge that can be easily seen from the cockpit, or preferably read by a passenger.
