Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Huge bog at 3k
Thread: Huge bog at 3k
Old 02-19-2011, 01:22 PM
355ci's Avatar
355ci 355ci is offline
what kind of electric pump is it? are u running stock lines? are u running a return? find some where under the car as close to the tank as possible to bolt it to the chassis. mount it with rubber shock absorbers lower then the tank. 1 filter before the pump 1 before the carb. At your power level a mechanical pump would be sooooo much easier. almost bolt and go
