Huge Engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2007, 08:27 AM
Huge Engine
Can y get a huge engine ( like in the pic ) but with only 500 hp that breaths flames ?
ID:	21390   Click image for larger version
Old 05-25-2007, 09:44 AM
DoubleVision's Avatar
Is this a joke?
Old 05-25-2007, 09:51 AM
no
I'm not kidding ...
I want to spend more money to make it realy big but without the added hp ...
waste of moneyy u may say but thats what y want
Old 05-25-2007, 10:09 AM
On the learning curve.
Why? if your spending the money why not get the extra hp also? breathe fire? Ummmm .... again why?
Steve
Old 05-25-2007, 10:20 AM
well
its going on a t bucket or 32 ford replica ... weight 700 KG and 1000 Hp ... not worth it
Old 05-25-2007, 01:14 PM
How fast is fast enough?
I saw an old T-bucet hot rod ata car show with dual 10-71 blowers on a chevy small block... everything was polished or chromed.. a complete waste of money, but it did look big, shiney, and was loud as hell. For flames just get a cam with a LOT of overlap, run your carb way too rich... it washes out the cylinder walls and is a good way to ruin an engine, but it will shoot flames.
Old 05-26-2007, 06:11 AM
Apparently someone doesn't know much about motors, or anything.
Old 05-26-2007, 06:22 AM
Johnny406's Avatar
Poncho Power
Build or get yourself a small block Chevy, and buy a tunnelram kit from summit.
Totally not practical but... who cares...IT'S BIG...
http://store.summitracing.com/partde...3&autoview=sku
Old 05-26-2007, 06:32 AM
RippinRon's Avatar
Stuff one of these in it.
Old 05-26-2007, 06:56 AM
a blower setup on a motor is approx $4000.....to "look really big"
a blower with virtually no belt overdriving gearing makes no HP....it's not forcing any air into the motor.......a 300hp motor would still be 300hp with a no overdrive blower...
build just a blower shell...mount it on top of a normal carb and intake manifold?
build some big valve covers?
to make flames:
http://www.eatmyflames.com/?gclid=CL...FSM8gQodHwPQKw
Old 05-26-2007, 07:21 AM
Wiki Edits: 31
he's probably seeing the huge nitromethane funny cars and Dragsters on TV with the huge engines, with huge blowers, spitting flames at night. what he dosen't know, is the nitromethane is what makes those flames, and you CAN'T run nitromethane on the street.
Old 05-26-2007, 08:34 AM
King of my Man-cave.
I knew that one was coming!
tom
Old 05-26-2007, 08:40 AM
zim@Eagle Mi.
Saw empty fibreglass blower shells some where. Did nothing but looked fine.
Old 05-26-2007, 07:49 PM
XNTRCI-T's Avatar
AKA Lee in KC
Umm, red, that's not exactly true. I'm running a 6-71 at 1:1 with dual quads on a moderately built SBC. My boost gauge sez at idle I have about 2" of vacuum, which means the blower is adding some boost, since normal vacuum should be somewhere above 16" (yes, I know the cam timing affects vacuum). At 2000 rpm the boost gauge shows a positive 2# of boost. At 3000 rpm it shows about 4#. At 5000 I'm up to 7# of boost. I gotta believe 7# of boost is adding one or two horsepower at the rear wheels.
Old 05-26-2007, 08:08 PM
Wiki Edits: 31
you might be getting somthing, but. it's taking 20% of your power just to run the blower, so your only adding what the blower is actully taking away. in the end you end up with about 0 hp added. 6 PSI is approx 30% increase in power with forced induction. even if you figure 10% of 400 hp, is only a 40hp increase.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
1973 Chevelle Malibu Engine Rebuild (pics 56k no) Malibu73 Hotrodders' Lounge 39 11-04-2008 12:37 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
Why high RPM's on the oval tack? steveyb4342 Engine 25 05-23-2007 07:50 AM
question for any engine builders out there mopar72 Engine 7 11-06-2005 03:06 PM
