Huge Ford Van Uniside - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2013, 11:21 PM
put up or shut up
first thought was where will I section it? Simple enough.
I try to have my donor panel 1/4" longer before I make my final scribe. In this area it will be about 1/2" just so I don't have to deal with that curve. I like the overlapped panel no longer than 1/4" so when it's cut out and laying flat your cut will be more accurate cause your scribe was more accurate. This sets you up with a nice clean open butt weld gap, which is not much. Good thing is there is three totally different places you can skip around to when you want your metal to cool so you will be constantly welding.
trusty porto power
could have worked this better but I want to ask what type of job this is before getting crazy on it. This was just to quickly get it back to where it needs to be.
11 hours on it and it's ready to weld on tomorrow morning. 2nd to last mock up for cut and scribe. Just can't get the rear door to line up due to the shape and another panel lapped on top. It needs to be cut out to gauge the gap so there's a little risk there. So with that in mind I'm ready to make a sleeve for the rear pillar if need be cause that's the gap it would effect to line up the quarter to the rear door... I think we'll be alright.
Before any welding I'll try to unbunch it a hair more. As you can see this thing was creamed. If I get this back to the mark the gap down low will be better. Keep in mind this is customer pay, otherwise this would have gotten pulled on the rack. Just using the tram gauge and plain ol common sense here.
I'll post more pics later.
Old 06-19-2013, 11:58 PM
Banned
why not the whole side, up to roof gutter
Old 06-20-2013, 12:14 AM
put up or shut up
oh, you don't want to go up there unless you have to. Too many panels sandwiched together and the skin is probably in the middle. Customers nor insurance companies will pay to do that for that particular hit so doing that will never happen on a production job. These cut lines I chose may not be factory recommended cut lines but I guarantee you they have a recommended cut line somewhere on that pillar, most likely in an area where you have space behind the cut line. Everybody does these vans this way. I will also be using panel adhesive on the areas around the glass opening. Plug welded everywhere else and open butt welded on the pillars. This one's a cinch. the only annoying part is the foam and panel adhesive on the panel as you put it on the car for the last time, and I have to find an access hole for a corner in the van that has a lot of foam, or at least I suspect there is a hole there(will look tomorrow).
Old 06-20-2013, 09:41 AM
put up or shut up
Hey Martin, you out there? If you happen to stumble upon this post and have some free time at work was wondering if you could check all data for a cut line spec on the van. I'm curious. Probably should have asked beforehand but this is a full on air chisel type of job and the side came in unexpectedly.
Old 06-20-2013, 09:52 AM
I'll take a look but it is probably in the center of the post.
Old 06-20-2013, 11:29 AM
There was nothing in aldata and I don't want to request something I don't really need and take their time. But I would think commonly (like 99.9%) the cut is about the center of the post. But on the same respect, there are more and more manufacturers who are putting in their guidelines NO used parts. ESPECIALLY "structural" which this would likely be regarded.
I know one thing, that project is one of the harder ones, making something from scratch is often MUCH easier than what you are doing. I am not implying that making a new quarter would be easier. But replacing a quarter, any quarter with a used one is pushing the tough work meter very high. And a full sized van? Yeow that is a mutha of a job, in my world you should get TWICE the labor than they give for a new OEM quarter. I mean think about it, you have to remove the damaged quarter without damaging the structure, then you have to remove the used quarter from the structure without damaging the quarter! It is a HUGE job and without twice the labor we are getting ripped off, but seldom do we get what we need on those used quarter jobs, they are a loser in my book.
Old 06-20-2013, 01:00 PM
Banned
understood, but when dad did them at the shop it was always to the roof.. never asked why..lol
Old 06-20-2013, 02:28 PM
put up or shut up
management's decision. 8 hours just to cut the donor out. If this were an insurance job they'd give no more than 4 hours. It doesn't make sense. As I was cutting out the side I looked over at the guy trying to get the donor skin off and mentioned his task was much harder than mine. There's foam around the filler neck and adhesive around the wheel lip so alot of extra work and cutting just to get better access to those areas. the tough part is plug welding on drilled out holes. The welds may not be clean as I wanted. I'd say if we just bought a new one and a resistance spot welder we'd me making a wise decision. If a shop has a plan to "eventually" get one, this would have been the time to fork out some cash so at least you know right away you got some of that money back.
Old 06-20-2013, 11:19 PM
put up or shut up
spent some time once again loosening the rear body mounts and brought out the porto power. It worked great! Then I started the welding on the uniside.
on this area,the donor skin was cut exactly 1/4" over. The scribe was more accurate on this and left a better gap than the other two.
'66 Ford Falcon Van could use help Mr.Fixxit Engine 5 04-29-2013 10:57 PM
'85 Ford Van: AmericanPackMule Electrical 4 02-12-2008 04:54 PM
'85 Ford Van: AmericanPackMule Engine 1 02-11-2008 07:38 PM
48 Ford Panel Van Mr Rob Body - Exterior 1 04-20-2006 07:09 PM
ford convertible van thumper57 Introduce Yourself 2 07-24-2005 06:11 PM
