When you paint you almost need to be a weather forecaster and anticipate what changes you may have as the day wears on. If I was in Southern California I would slow my material down. With a medium reducer and the temperature getting warmer any moisture is going to show up. Did your compressor work hard before any painting?
Checking the temperature on the roof is fine but, it's the ambient air temperature and moisture content you have that makes a difference. The higher the temperature the more moisture it holds. Fore example, I live in Canada and we get a pile of snow every Winter. If our humidity content in Summer would be what it is in Winter, most of Canada would be a dessert. I hope this makes sense.
There's your problem...5 HP is usually fine, it's your reserve capacity that's killing you. Now I said 5 HP is USUALLY fine. In the compressor world many manufacturers lie and call their motors 5 HP when they truly should be rated at maybe 3 HP. The other thing you need to look at on a compressor is CFM out put. Paint guns use a lot of air and your compressor should put out at least as much or more CFM than the paint gun manufacturer recommends. 10 or 12 CFM isn't enough unless your using an air brush. 25 gallon reserve is excellent for filling a tire, not painting. When you paint you will drain that reserve tank very quickly and your compressor will run constantly...causing heat, causing moisture in your tank, causing moisture in your air lines and ultimately hazing off your paint work.
I just checked my portable compressor for my air brush and it's running 8.3 CFM and I can almost put that compressor in my pocket. So in short...it appears to be a moisture problem. The moisture is coming from an undersized compressor, coupled with a warm ambient air temperature to really heat up the air your using causing condensation. The fix, acquire a compressor that will more than handle the CFM requirements of the equipment (if you get a compressor that will handle more CFM and reserve capacity than you need it will last longer, reserve capacity should be minimum 50 - 60 gallon) your using and your problem will be solved. I understand, simple, if only it didn't cost so much right. Hope this helps Ray |
Another thing you should be concerned about in SoCal is the quick drop in temperature in the evening. It usually drops below the dew point at night, and with those high temps, the dew point will probably be higher also. So spraying outside in the evening is not a good idea.
Make sense? Hope this all helps. Best of luck Ray |
| The Following User Says Thank You to 69 widetrack For This Useful Post: | ||
dogwater (10-24-2012) | ||
Quick note...on a hot and humid day my AC unit in my house can create a fog cloud so thick you'd think Charlie Sheen and Fidel Castro where having a cigar smoking contest in my living room.
Ok good info guys. I have a 60 gallon compressor but I have no 220 in my garage. Now it I had to paint small parts like I still have two what can I do prevent this. I have a few pieces left that need to be painted. The thing is I work 7 days a week and get off till 500 pm. Will days with less humidity or using a heat gun during coats help.
Days with less humidity will help and would be recommended...heat gun...NO...NO...NO. Your asking for more problems. It's way to easy to surface dry and not cure your paint with a heat gun. Body shops with an air make up unit don't bake their paint in-between coats, and neither should anybody else. If you do this you stand the chance of top drying your product and when you put more product over top the solvents will react with what you just painted and crack and blister and mess up what you just painted. Even after your last coat, leave the heat gun alone. You say you paint after 5 PM, well, paint your pieces, go to bed, let nature and the chemicals do their job and admire your painted parts in the morning. Thanks Ray |
Good advice widetrack. I wired it for 110 but after it fills to a certain point the motor will come to a stop. As the motor is not getting enough amp to fill the tank. I was reading other threads and.some recommended using a hotter reducer.
| humidity | atticus0846 | Body - Exterior | 1 | 02-18-2012 10:28 AM |
| Is 80% humidity too humid? | mangoose | Body - Exterior | 11 | 12-09-2009 08:57 AM |
| Humidity and paint | eighty-one | Body - Exterior | 3 | 03-28-2009 06:40 AM |
| Humidity | Mrwood | Body - Exterior | 6 | 06-06-2008 10:27 PM |
| Paint and humidity?? | Bluepen | Body - Exterior | 1 | 06-29-2004 03:27 PM |
