humming noise from tranny - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-12-2005, 02:55 PM
Has New Tranny Th350 New Torkmaster Torque Converter.when It Gets Up To Operating Temp The Tranny Or Converter Hums Driving Or In Park It Seems To Get Worse As You Increase Rpm And There Is A Vibration The Car Is A 74 Nova With A 350sb And Turbo 350 Tranny What Could The Humming Be Any Help Would Great Thank You
Old 11-13-2005, 08:56 AM
BOBCRMAN@aol.com's Avatar
I'll have to stick my neck out here,, But. Every time I have seen a trans that hummed or whined it was a front pump/convertor problem or a restricted filter or filter installed incorrectly.
Overefficient cooling system and popping noise. TVR383 Engine 8 11-09-2005 08:17 PM
TCI tranny noise ??? A/G WILLYS Transmission - Rearend 8 10-02-2005 07:59 PM
350 Tranny noise, not sure what it is... Juicer Transmission - Rearend 3 10-07-2003 09:39 PM
th-350 clanking noise then grinding the nothing roadrash9r Transmission - Rearend 8 12-09-2002 03:32 PM
4-speed tranny making noise!!? chevyelc81 Transmission - Rearend 6 08-04-2002 07:23 PM
